I haven’t finished it yet. I have the settings dialed in for the particular white oak that I am using for the base. This is old white oak from barn wood that I planed down. It’s got a very tight grain and is quarter sawn so that means there are ridges from the grain standing up in the engraving. I need to have a little higher dpi to get the bottom smoother and a uniform depth. I also tested it with the raster going at a right angle to the grain.I just haven’t had an hour and a half to devote to babysitting the engrave that it will take. Maybe tonight.
Ah ok, I thought you were using proofgrade veneer. I was going to attempt something with that. Either way, Id love to know what settings youre using. Cant wait to see the finished product too!
I’ve been meaning to ask What type of planer are you using?
Or, perhaps just copy the QR code and put it on the reverse side
im [quote=“takitus, post:59, topic:4422”]
[/quote]
I am using the walnut and maple proofgrade veneer. It’s about 3/64ths. They will be the inlay pieces to make up the compass rose and put in the relief I have engraved into the white oak.
It’s engraving as I write this. Actually 1 hour and 56 minutes. I’ll post it as soon as I do a dry fit. This is a test piece full size to make sure I have the engrave accurately sized.
I have a Grizzly 12", their entry level. This old white oak is pretty tough on it to do a full 8" wide board.
The trial in a full size engrave of white oak is finished. I can’t use this particular wood for the base to inlay into. The engrave doesn’t leave a smooth enough base. This is almost perfect quarter sawn so it is going to expose the most of the growth ring pattern without it being endgrain.
This is understandable and has nothing to do with the Glowforge but demonstrates the variable density of wood according to growth rings. White oak is also particularly dense and aged white oak like this is super dense. Have you ever tried to pound a nail into an old white oak board?
Because of the variations in the surface depth of the engrave the veneer is proud in some places and recessed in others.
The edges of the engrave also are affected by the growth rings so I don’t always get a uniform shoulder to but the inlay against.
There is also a design issue with how all the inlay pieces go together. It seems to bulge out on the right side so my engrave is just shy of large enough on the right side. Everything else will fit in perfectly once the masking and backing is off. Just the whole base variation.
I have some flat sawn white oak I can use. I might just go ahead and use the ProofGrade maple plywood. That would ensure an even depth.
Anyway a learning experience. I’m open to suggestions, comments and corrections.
One additional point. The residue like burnt coal tar is pretty strong on the masking. It also builds up on the shoulders of the engrave, depending how it lies in line with the air assist. To get a crisp shoulder I needed to clean it out of some of the edges. Interesting how this would behaves.
Very nice! I hope you can still use that piece of white oak for something (the engraved color is a nice contrast against the lighter wood if you were doing some engraved writing or sign). Glad you were able to find some time to babysit ! Hope the GF isn’t taking you away from any important stuff !
Awwww, shame about the white oak not working. Could you maybe engrave very deeply then pour some resin in to level it a bit? That would be pretty hard to do I suppose. Regardless, I think it’s going to be a gorgeous piece when finished.
I agree with Cyndie on this one…that’s going to be stunning when you get it locked down. (Interesting seeing all the wood issues too…inlay is really an art form.)
or engrave just a bit too deep and use some wood filler under the inlay pieces, squish them into it, and wipe the excess off as extra “grout” ? Just a thought… that may be terribly ugly.
I think that you are right that proofgrade for the base is the way to go. I love the design! this is going to be so beautiful, and I’m really enjoying living vicariously / watching the whole process
I noticed sanding the Beech butcher block top for the automated desk, there are a few pieces in it that are quarter sawn. Running my hand across the surface, I was surprised to find apparently the quarter sawn surfaces are harder because they are slightly raised.
Just an observation I didn’t anticipate, so I would expect that settings for cutting/engraving may be slightly different for the same wood flat sawn or quarter sawn to get identical results.
Chisels, abrasives, lots of time and even more patience?
For sure it would be best if everything is perfectly level, but it might be help if the veneer sits down just a bit and then you sand the oak down to flush. Little variances in veneer height can be handled by sanding through a drum sander or by planing smooth.
In my experience of stone inlay, the final perfect elevation is achieved by cutting the assembly down together. Sanding the base down until you just touch the veneer is how I would approach it also.
I think a drum sander is the next woodworking machine I’ll build, well after the CNC. I’m still going to work with how one would put some inlay in an engraved board like this, but tonight I’m just going to get some ProofGrade and etch that to the right depth and finish it up. I need to put this thing to rest!
Even getting very close to the exact depth, unlikely the two elevations will be perfect. I would count on having to do some sanding to achieve that. After all the work you have put in to it, it would be a shame not to get it just right. if you are weary of dealing with it my advice is to put it aside instead of pushing it through. It will wait for you.
Anytime I ‘cut to the chase’ just to put an end to a project, inevitably there will be some small detail that catches my eye every time I glance at it. coulda’ - shoulda’.
You are the artist, so your call. It may be that the precision of the laser will prove me wrong.
I have three hand sanders at the ready with quite a few different grits. One thing is ProofGrade is lightly finished already so to have an even finish, I’ll have to sand off the finish anyway.
It really is a fine piece, looking forward to the finished product - probably not as much as you though!
I’ve been thinking about how I would do this and the only thing I keep coming back to is the following.
- Engrave deeper than the inlay material, maybe even two or three times deeper.
- Then partially fill the engraved area with an epoxy resin that will flow and provide a smooth uniform surface on which to mount the compass rose.
My concerns would be filling the engraved area too much or having the resin up the sides of the engraved area causing the inlay not to fit correctly.
Just my two cents, hope it may help with the brain storming on this project.
Would it be cheating to cut the areas where the white oak shows out of white oak veneer and mount everything on a flat substrate? No more leveling problems that way. Maybe that violates the spirit of inlay?
