HELP !!!NEWBIE CANT GET MY ACRYLIC TO CUT ?WHAT I’M I DOING WRONG
using 500/ 60 need some assistance
That’s way too fast and low power.
Check out #6 in this post:
You can find a good test method to dial your settings in on any new material. Piece of cake!
Also welcome to the forum, sorry it’s not for a more fun reason ![]()
When using non Proofgrade material, select a similar proofgrade material as a place to start your testing. Select one of the acrylics and look at the cut settings. You will not see speed 500.
I use these settings for cutting cast acrylic:
1/32 thick - 300/100
1/16 thick - 200/100
1/8 thick - 175/FULL
Maybe those will get you started.
Thanks guys I was able to make the adjust and Bam it cut
If it’s typical 1/8th" acrylic (tap plastic, inventables, home depot, etc.), then my default rule is “just use Red”. PG Red’s settings are my go-to settings for most colored 1/8th" and 1/4" acrylic. If the acrylic is more blue, then “just use Blue”, and if it’s clear then “just use Clear”.
The only real issue is the cover tape.
I see that you got your answer for this - but for the future, might I suggest going through:
Especially for acrylic there’s very few times you’d need to work in manual mode, and using the
provided pre-sets is faster than trying to figure out manual settings every time!
