I am a teacher and need alot of material to start I plan to get some proofgrade the kids may bring some of their own wood. How do I know what settings and is there some wood that cannot be used.
I donât have much experience with non PG woods (yet), but I use lots of other non PG materialsâŚ
For settings, start with the closest PG option to what it is (or you think it is), and then if itâs a softer or harder wood, adjust a bit, and then test (or at least donât remove the board from the bed until you confirm itâs been cut through). E.g. cedar (soft) will not need as much power as walnut or oak (hard) for etching and cutting.
Risk of using non PG plywoods is you donât know if the glues used will release any toxic chemicalsâor any other treatment for the wood. And have a fire extinguisher or a spray bottle of water on hand in case you do get more than just smoke!
Also the density due to knots in the wood or type of adhesive and filler layers will always contribute to variations in the results, too, so even if etching on plywood looks great, the cutting may be affectedâŚ
Good luck!
You will want to use the search function in the upper right corner to learn how to test your materials and what to look for. This question has been answered many times. There are also many resources online as the GF is not the first 40-45 W CO2 laser on the market.
My go to cheap wood that I can get whenever is a 1/4" lauan from the big box hardware stores. Once side is usually in good shape. There are issues with voids and knots, but at $6.00 for 2x4â sheet, it works great in a pinch. Just do some tests using the settings for thicker plywood. You can re dimension it with just a good utility knife and score deep on both sides.
Lots of other places to go, depending on where you live. Lots of posts about alternate wood sources.
Beyond the manual in 3⌠2⌠1⌠
You canât allow them to just bring in any random material, because you will end up spending hours chasing down settings - assuming you can accurately identify what the material is! A lot of material looks similar, i.e. there are plastics that appear similar but some can damage the machine (and you!) while some are completely safe.
I suggest you get an idea of the things they would want to make, then find local sources of materials that are suitable for those that donât want to pay for PG materials.
Testing is the only sure way to dial in the settings. The proofgrade materials have a few advantages depending on what you are after. #1- they are safe. There is no sanding, staining or finishing and it is masked, so when you pull the mask you are done - except for assembly if there is any.
Like @eflyguy said, you need to use known safe materials so put restrictions on what the kids can bring in.
It wonât take you long with a heard of kids, to get an understanding of limitations - and soon you will be the coolest teacher going! ![]()
Not all woods are created equal, but most you find in places like Home Depot will be usable.
I have found this site to be handy for the âoddâ woods.
Explanation of some terms at the bottom of link.
My 1/8 meranti lauan chars so badly I hate to use it. Luckily I can get Baltic for a very low price so I just use that for almost everything.
I have used that Lauan and like the look of the less than paper thin surface, however at $15 a 4x8 foot sheet that I cut into 5 - 19 x 48 inch sheets Revolution ply starts a 3/4 the price and gets another 25% more useful pieces. Still less than paper thin, and mostly only one side nice, but many fewer voids (Only where two big sheets go together there is a line) and it is barely more laser resistant than the base wood, and it is far more eco-friendly as they go out of their way to point out.
For other pieces of wood (make sure it is not pressure treated, as that makes it very bad) you can used this to check out the best settingsâŚ
I would look at this problem from a âwhat are they going to do?â perspective.
If they are going to cut out stuff, I would approach it as:
- Set a max material thickness. You really donât want someone doing nine passes on a 3/4" piece of wood.
- Non-resinous domestic hardwoods. There are exceptions to this rule, but do you really want to deal with them?
- Plywood has to be true Baltic Birch or an mdf core. Remember, there will be part of a cut that doesnât go all the way through. How old are your students? At some point youâll need to free a piece with a utility knife if youâre not using proofgrade.
If they are just going to engrave piece of wood that is less than 2" in height, and fits in the machine, settings donât really matter. Engrave it and if it isnât deep enough do it again (just donât move it.)
I have 9-12. Thanks for the info. I think will work with proofgrade until we get comfortable. Then venture out.
