Delivered my first custom box today. Took me a couple trys to get it right. Did a inner box that I painted then glued a frame on the outside parts. Painted the inside with white lacquer. Engraved a 1/8 acrylic for the glass in reverse.
Thanks! Never mind my corners that didn’t match up. I filled them in with some black epoxy. I might save that technique though cause it gives the corners and angle and almost a very smooth grout feel.
Ahhhh. I didn’t get a picture of the under side of the top. But I’ll try to describe it for you. It is a drop in. If you flip it over I had a 1/8 inch frame that I glued to the back in which the acrylic sat in. First I glued the frame then I glued the acrylic. Then I got some 1/8 leather banding and glued it around the frame so it had a soft close effect. I’ll see if my friend I made it for will send me a picture of the under side of the top.
Ok, here is a picture of the back. As you can see I used a white caulk to finish off the seam between the acrylic and wood. Next time I’ll probably just use the same clear glue that I used to glue the acrylic down.
