For my birthday, my kids gave me a set of leather stamps. Even before the thought of using them came to mind…and just because I can, was the thought of making them a proper storage box. It’s a 5" x 6" x 1" med. draftboard box with a secondary piece of 1/4" inside with holes cut to hold the stamps. The sliding lid is med. PG clear acrylic, engraved with a sun symbol using the trial features in the UI. I painted all the pieces with red, purple, and gold Unicorn Spit before gluing together.
Nice! I think it would work great as a jewelry box as well. Particularly for rings—just cut slits slightly wider than the average band size into the foam. One slit per ring.
It would work for rings great like that if you cut the inner thing out of foam. It actually looks like foam though, doesn’t it? That’s because it’s painted with sparkly Unicorn Spit. Foam is what they originally came in when I first got them, but it got mangled (by me) so I couldn’t use it . This one is made out of thick PG draftboard.
Wow that stuff is something else! It looks a lot like felt/fabric, which made me not only have to reread what you wrote, but double check the pictures to see what you meant.
