How be the hinges go in?
Welcome to the forum.
If you click on the link provided to boxes.py there is a close up photo of the hinged area that might help you.
Itried no luck
I still use a recipe box⌠and I need a new âvolume.â Thanks for this!
No luck seeing the hinge or no luck figuring it out? I havenât made this box, but here is the pic from boxes.py
I slimmed them down and using thinner Baltic Birch plywood was able to make them stronger and less clunky without sacrificing strength ![]()
I found it inherently weak and quit using it.
what do you use to interlock the hinges? The couple that I did I had to use a brass rod. but my metal cutting skills are less than ideal.
I really like this design and made one. Iâm not sure if I downloaded the file incorrectly but the box ended up being 3 x 5 outside measurements so I had to cut my cards down to fit inside.
Also I am not sure how to insert the hinges. I can usually figure it out but this is perplexing me. I canât see the hinges in the picture to figure out how to add. Can you help me out?
Do you see the hinges in the posts right above yours?
Hi, I downloaded your file but it looks like Iâm only getting the first page of it. Is there another download I can use? I canât wait to put it together!
There are several files included above. There is recipe box 1, recipe box 2, and recipe box dividers and inside box.
Click on each segment above and save image as svg.
Are they the .ai file shared in Dropbox? Or are they different links?
Click on what look like line drawings under the original post.
That worked perfectly, thank you!!!
