How do I or can I remove the burning markings from the cork.
I’m not sure you’re giving us enough detail to help.
Got a pic or more detail about what you’re doing?
I have successfully cut and engraved cork without substantial burn marks, so I am just guessing here that you could either adjust your settings and/or wash the burn marks with soap and water.
I am pretty sure that there are all sorts of different kinds of cork, so that may be one reason your results are different than others have had with this material. I found this post helpful when I was preparing a cork project: Played around with some cork!
If you’re wanting it to be black like to have there, you can mask the cork before cutting. Otherwise, I’d use a lighter setting. It looks to me like you’re over burning the cork. I don’t have any experience removing the smoke residue from cork because I just use a light engrave to discolor the cork.
What @drellum said. Way overpowered. Try more like 5 power, cork requires almost no laser to go very dark.
And you can sand cork to remove smoke residue if you need to. It’s just easier to go with less power, I never have to clean my cork up.
Thanks. I think I just used too much power.
Lamar M. Ware
Staining can be removed with Alcohol Hand Sanitizer though I would test it to make sure it does not dissolve what is holding the cork together, I have also used bleach tile cleaner to bleach out stains. I have heard Ammonia also works but do not use them on the same piece as they can be nasty when together.
Dry magic sponges work a treat as well.
I’ve been using straight lemon juice to kill residue stains. It’s magic.
Thanks.
Lamar M. Ware
