I think I’d go the opposite actually, it really depends on how intricate the design is. If it’s moderately intricate, you’re relying on the power modulation to power things down accordingly.
If you push print a few times with different settings, you can identify where the motion system becomes the limiting factor.
Through my different systems, I always thought that accel and decel was a pretty figured out thing. Find my max cut speed / power scenario and roll with it. But after a lot of experimenting, I found that by reducing the speed and the power, I was actually able to improve processing times fairly often.
Either way, now the OP had a few different ways to test.
I don’t doubt that, but in terms of soot reduction, generally faster is better. Even better — two light fast passes will probably make even less soot.
Soot is charring in the surrounding material which is almost always made worse by slower speeds- thermodynamics come into play but the basic theory is that if you give the material more time to absorb the energy the heat can propagate into the surrounding material and char.
Of course experimentation with that specific material is probably in order but if char was my top worry, lighter and faster is how I’d go.
The main point is that if it’s an intricate pattern, the system is having to slow itself down anyways, but it’s fighting to also accelerate and go faster. You’re relying on the software to modulate the power up and down, which is absolutely better than it used to be (clean corners and all), but it’s still just a software control, and as good as the programming behind it.
My experience has been the opposite on a lot of the paper based stuff though - lower power with an appropriate speed usually leads to a cleaner product both as far as the soot and the product face.
For removing any soot that does remain (after all the trials with adjustments others noted), when I’ve done cardstock like yours (your pic reminds me a lot of some that I have used!), a slightly damp washcloth helps–I get packs of white ones when I can find them cheap, so I can tell if they are getting sooty enough to where they deposit rather than remove it… and toss into the washer when they need cleaning. This heavy metallic cardstock seemed OK with a very light handling with slightly damp cloth–but my work was not nearly as intricate as yours–which is lovely, BTW!
+1 for dialing in your settings. I cut 110-130lb metallic card stock regularly and, do not have a lot of trouble with charring.
For light-colored (mainly white) stock, I do sometimes use strips of Post-It tape to pick up the any stray ash along cut and engrave lines before even taking the piece out of the machine. That is sticky enough to pick up the powdered ash but, won’t mar the surface of the stock. Then, there is less stray ash to accidentally smear on the surface of the piece. I can generally use one piece of the tape for several passes without it re-depositing anything.
I am typically using a Seklema mat, which provides similar ash containment service for the reverse side.
I use a really soft paintbrush, and just gently brush the ash away from engraved areas. Seems to work really well.
I used the brush extensively here:
Granted this is a bit off topic and clearly you can see I didn’t bother dialing my cut settings in, hence the flashback pattern, but the ash brushing seems to really do the trick without smearing.
My main problem is soot from scoring. So intricacy does not apply here, it’s just a straight line. I’ve done quite a bit of testing, and whether I do 100s/1p or 500s/20p I still end up with soot. I even tried 500s/10p x2, all sooty. This is what makes me think it’s inevitable and that I have to just deal with removing it. Could be related to my paper I guess.
EDIT: In all cases I made sure to use the minimum power that would do the job
Would you consider doing the scoring manually, not on the GlowForge? Once you had your setup/ rhythm going, it would be a lot faster than wiping down each invitation. You could make a jig or use a straightedge, then there are many options for what to score it with, such as an embossing tool. Even a delicate dent makes for a nice fold.
I’m a big fan of jig once, create many. Another simple approach could be to put tiny marks on your design, at the top and bottom of the fold line, to guide your straightedge. Pretty cards, btw!
I put a small shop vac by my glowforge, and after every job, I give it a once over with a brush attachment, the soft bristles don’t hurt anything internally
Hi I’m having trouble cutting cardstock on a pro - what settings do you use? I have a basic. Was working at 300/55 but design is intricate and not cutting consistently. I used the seklema mat but still blowing…any suggestions?
Thanks!
Hi I’m trying to cut an invitation too and having trouble. Can I ask what settings you used? I have a basic. Looks like you might have used metallic stardream paper? Mine is slightly thicker. Any suggestions appreciated! Thanks!
You are in the range of settings I use for intricate cuts, typically 300/50-60, depending on specific stock and design.
For anything other than full power, Basic vs Pro should not matter. Different machines seem to have some small variation, though.
Sometimes, the same settings will go through fine for some cuts but, not others. Mostly, I see longer straight cuts going through fine with some smaller details not.
In those cases, I will usually move the problem cuts into a separate operation and, reduce the cutting speed a little and/or bump up the power a few points. I sometimes make a custom test patch out of some of the problem area to dial in the settings (rather than running the whole job over and over).
For very fine detail, it is often better to do an engrave that goes all the way through. Note that that is hard on Seklema mats. So, you might want to explore other work hold down options if you do that.
I use a rubber scraper to make sure my stock is evenly adhered to the Seklema mats. They also become less sticky as ash and other residue accumulates on the surface. I periodically wipe that off with paper towels and copious amounts of isopropyl alcohol to restore the adhesion.
I sometimes use additional hold down on the edges of stock when it is being uncooperative. Magnets are generally not recommended because they can cause problems and errors with the air assist but, thin, flat magnets on card stock, placed away from the cutting area do not cause problems in my experience.
Thanks so much for your reply. I have done tests on a small area of the design and it seemed to work at 300/50 but when I went to do the whole design it doesn’t cut thru. Paper is 111lb coverstock. Depth set at .02 and using mat. Tried 300/45, 300/55 neither were right. I have 168 of these to cut. Any thoughts on settings or Am I doing something wrong? I did a similar project when I got my GF on Stardream and 300/55 worked perfectly without much char. This paper is a dark blue also. Thanks!
Part of what I was trying to convey before is that I probably can’t give you settings that will just work. Despite the interface having quantified settings, there is really a lot of variability where the rubber meets the road (or where the laser meets the paper). In particular, there are variations in speed and acceleration as the machine cuts around small shapes. The software tries to compensate to keep it even but, there is still variability.
You need to have a (metaphorical) conversation with your machine about your project. My previous suggestions were about ways to explore what might get you to a working solution.
One more for that list: I have sometimes resorted to using two lower-powered passes or, adding a second cut just outside of the kerf of the first cut to get stubborn bits to cut completely. Let me know if it’s not clear what I’m saying here and, I will try to illustrate.
I routinely use dark blue and black stock. So, the color should not be an issue.
I cut a lot of 110lb stock and, even use the Stardream regularly.
I mostly use set focus rather than setting material height. If you are setting manually and not accounting for the thickness of the mat, that could definitely make it not cut through consistently.
Another thing that is worth trying: clean your optics. I am noticing a significant difference in cutting through with freshly-cleaned optics vs after running even a few jobs.
If you want to share your design, I might be able to make specific suggestions.
