Hey all! Thinking about making some production runs of little gaming tokens and whatnot, and my wife and I realized the labor involved with removing paper backing (such as proof grade acrylic) will add a fair amount of labor time.
I feel like there must be a way to reduce the time spent on this tedious step. Does anyone have a tried-and-tested technique for loosening the adhesive so the backing basically falls off. We tried soaking acrylic in some warm water for a while, and while it did help it wasn’t all that much easier. I also tried using warm water in an ultrasonic cleaner, which was just as good as soaking for 5 minutes. That said, it’s still not falling off on its own.
My next step is to try out some different cleaning chemicals in the ultrasonic, like glass cleaner, Simple Green or even something serious like Goo Gone. I don’t think that’ll bother the acrylic, but I would test it first.
Before I get into all that testing, though, I figured I’d ask you fine folks. Have you found something that works?
