A couple days after campaign price was $600.
Plus (if memory serves) $75 shipping.
Iāll let you know for sure in 5-10 business days when I get my refund checkā¦
This is an email i got from support.
You donāt need to replace the coolant. There are two primary parts that may need attention.
First, if you get a model with the air filter, is the filter cartridge. Itās difficult to estimate how often the filter cartridge needs to be replaced because it depends not just on how much you use it but on the material you use. Hardwoods arenāt very taxing but plywood might be, depending entirely on the glue (which is usually hard to figure out). Itās just going to vary a great deal, with light users pushing past a year between changes, and heavy users who are cutting nonstop turning them over as often as every month or so. Weāre working on filter pricing, but we expect itās going to come in under $250.
Second, for every model, is the tube. The Glowforge tube is custom made - itās bigger than most desktop units (850mm) and has some modifications for longer lifetime and smaller spot size. Itās rated by the manufacturer for 2 years, but weāre doing lifetime testing now to dial that in a little more closely. The tube is covered under the warranty. Out of warranty, weāll replace it and realign it for you for $499, including roundtrip shipping in the US. Weāll also have a replacement tube part available for purchase.
Unfortunately, replacement parts are not yet available for purchase. When we make them available, you will be able to place an order at glowforge.com. Weāll announce that to all our customers when it happens.
