I recently upgraded to a phone with wireless charging capabilities. As a result of previous experiments with wireless charging, I had a partially disassembled wireless charging system that was originally enclosed in an ugly black stand. Now that I have a , I thought that I would use this as an opportunity to design a custom stand while also learning Autodesk Fusion 360.
I couldn’t be happier with the results!
I used walnut plywood for exterior faces, draftboard for an internal support, and walnut veneer for the surface that my phone rests on just above the inductive charging coils.
The circuit board hangs behind the charging coils:
My favorite part of the design process is the speed at which I can now iterate. In less than 10 minutes, I can make an update to my model in Fusion 360 and cut and assemble a new cardboard version of my model. Contrast this with my Makerbot Replicator 2 which would easily take a couple of hours to print each revision.
Here is a picture of the evolving model, starting with early cardboard prototypes, enhancements printed with draftboard, and the final version in
walnut (with Shoji Votive Candle Holder for scale).
So much fun! Thank you @dan and the rest of the team!
