Yes, the alignment is off. This is just a draft. I’ll cut a template next time!
Ceramic tile engraved, then painted with 3 different sharpie oil based paint pens. Super easy. Super cheap. Looks snazzy!
Yep, sure does!
Next time you do this, if you want to make sure it’s properly centered, try throwing a piece of paper in your glowforge and cutting out the shape of the tile. Then lay the tile in that spot, and etch. That will act as a jig/reference point for your cut.
Yeah, looks good!
I use a piece of cardboard held down by magnets when I’m not being lazy. Cut out a tile shaped hole, done.
That way, the tiles have something to sit in that keeps them aligned.
