I read a great article by Tim Deagan in issue #90 of Make magazine (no free online version, yet.)
Here is a PDF I made from the article he used for straightening photos for engraving and tracing.
Deskewing Frame - Print Out.pdf (2.1 KB)
Here are my best guess on how to use it on other programs… Once you have it cleaned-up you can take it further in make it a vector.
GIMP
- Open the Image:
- Open GIMP and load your image.
- Select the Perspective Tool:
- Choose the “Perspective Tool” from the toolbox or press
Shift + P.
- Align the Fiducial Frame:
- Click and drag the corners of the image until the fiducial frame aligns with the grid lines, making sure the corner marks (black circles) form a perfect rectangle.
- Apply the Transformation:
- Press “Transform” to apply the perspective correction.
- Measure the Current Size of Corner Marks:
- Use the “Measure Tool” (found under the Tools menu or by pressing
Shift + M) to check the current size of the rectangle formed by the corner marks.
- Scale the Image:
- Select the “Scale Tool” (
Shift + T). In the tool options, set the width to 7.25 inches and the height to 9.75 inches, ensuring the aspect ratio is locked. Adjust the size until the measurements match these values.
- Crop the Image (Optional):
- Use the “Crop Tool” (
Shift + C) to remove any unnecessary parts outside the fiducial frame.
- Export the Image:
- Save your corrected and scaled image.
Affinity Photo
- Open the Image:
- Open Affinity Photo and load your image.
- Use the Perspective Tool:
- Select the “Perspective Tool” from the toolbar.
- Adjust the Perspective:
- Drag the corners of the grid to align with the fiducial frame, ensuring the corner marks form a perfect rectangle.
- Apply the Changes:
- Click “Apply” to set the transformation.
- Use the “Rectangle Tool” to draw a rectangle over the corner marks, then check the size in the transform panel.
- Scale the Image:
- With the “Move Tool” (
V), adjust the dimensions so the rectangle measures 7.25 inches by 9.75 inches. Lock the aspect ratio if necessary.
C) to trim any excess areas outside the fiducial frame.
- Export the Image:
Adobe Photoshop
- Open the Image:
- Open Adobe Photoshop and load your image.
- Use the Perspective Warp Tool:
- Go to
Edit > Perspective Warp.
- Create a Grid:
- Create a grid around the fiducial frame, ensuring the corner marks form a perfect rectangle.
- Warp the Image:
- Switch to “Warp” mode and fine-tune the grid to align perfectly with the fiducial frame.
- Confirm the Changes:
- Press “Enter” to apply the perspective warp.
- Use the “Ruler Tool” (found under the Eyedropper Tool) to measure the distance between the corner marks.
- Scale the Image:
- Go to
Edit > Transform > Scaleor pressCtrl + T(Cmd + T on Mac). Adjust the size until the rectangle measures 7.25 inches by 9.75 inches. Lock the aspect ratio to maintain proportional scaling.
C) to remove any parts outside the fiducial frame.
- Save the Image:
