I just received my Glowforge a few days ago and after doing some test prints on proofgrade materials, I’m venturing out on my own materials ( I was a bit concerned it would start a fire - so had my fire extinguisher and wet towel ready to throw on the wood if needed )
I work with reclaimed wood lath in a lot of my projects, since it’s not a plywood with glues or treated wood, I figured it would be “safe” enough to give a go in the Glowforge. It’s 1/4" thick so I couldn’t cut through it… I was able to etch on it though.
Now I just need to learn how to make vector images, edit them and customize them to my liking vs being stuck with available vector images…
It should be able to cut that. The trouble with lath is it’s often got other stuff absorbed into the would, like plaster, that might prevent it from being cuttable.
I bet there’s a fairly high concentration of plaster in it. The plaster goes on wet and that lath just soaks it up and then it dries over the course of a hundred years Started out as roughsawn oak I bet and turned into rock over time
I would be surprised if slowest speed and highest power didn’t cut that easily. I suppose the absorbed plaster might be a slight issue.
My only experience is with a pre-release unit, So I can’t really speak for the production units. It is possible this machine has a pro tube in it, I have just been impressed on what it can do. I cut right at 1/2" oak with this at slowest / highest power
Your work is great! marvelous use of that material.
