Hi there,
Here are laser cuttable bits for secret hitler (which is released under the creative commons license).
Secret hitlet.ai (3.4 MB)
secret hitler box.ai (274.1 KB)
leegill beer sleeve.ai (5.5 MB)
this has plans for the boards and a way to cut out the wood decision pieces for the roles, plus card designs to use (I printed them using a card printing service). The tuck box is for a different rethemed version of the game I setup. Much easier to organizer larger projects like this with multiple pages in illustrator I find than in something like inscape, which is why I include the illustrator files here.
Added some svg files to this as well. These are the ones I cut out anyway, the main boards I printed and then cut out a chipboard base to glue them too, used black paper to cover the chipboard first and then glued on top of it. Looks pretty good in the end… I added the templates for the black paper i used for the draw and discard piles too (although you could do those directly with wood). The president and chancellor I painted the boards first and then engraved cut them to make into the folding boards, then I put everything in the box
The sleeve is a bit tricky. I used cardstock and then score with the laser to make fold lines and then cut along the other lines. I printed it on paper and then use that box on the page to cut a template in something else to place the paper into so it will line up when the box is cut for folding (this is also how I do the tuck boxes for the cards).
Thanks!
David.
