Right click on the images here and save to your computer. They are dim for kind of hard to see.
Thanks for your generosity.
I moved this to the Free Laser Designs section .
Thank you! Looks like fun!
Thank You
Nice job. Thanks for the share.
Iāll have to check out this game! Iāve spent a lifetime playing solitaire and this looks like fun. Thanks for the share!
Fun, thanks!
@ovm.steve This looks fantastic! Silly question: where are the files for it? And thank you!
You are very welcome.
To build the game board for Sequence
Copied from Wikipedia:
RULES
Sequence can be played with 2 to 12 players. More than 12 players cannot play. If more than three people are playing, they should divide evenly into two or three teams. With two teams, players alternate their physical positions with opponents around the playing surface. With three teams, players of a team must be positioned at every third player around the playing surface.
If the player who played first wins and the second player wins in the next turn itās a tie.
The game board is placed on a flat surface (such as the floor or a table) with enough room to allow for the draw deck, a discard pile and marker chips. The jokers, if any, are removed from the deck as they are not used in the game.
To decide who goes first, one player shuffles the card decks into two stacks. Each player takes a card from the deck. The player with the lowest card will deal, and the cards are shuffled again. Each player or team then chooses a set of poker chips; all members of each team must use the same color chips (red is only used if there are three teams).
The number of cards dealt to each player varies by the number of people playing:
Each card is pictured twice on the game board, and Jacks (while necessary for game strategy) do not appear on the board.
The player to the left of the dealer goes first.
The player chooses a card from their hand, and places a chip on one of the corresponding spaces of the game board (Example: they choose Ace of Diamonds from their hand and place a chip on the Ace of Diamonds on the board). Jacks are wild. Two-Eyed Jacks can represent any card and may be used to place a chip on any space on the board. One-Eyed Jacks can remove an opponentās token from a space. Players may use the Two-Eyed Jacks to complete a row or block an opponent, and One-Eyed Jacks can remove an opponentās advantage. One-Eyed Jacks cannot be used to remove a marker chip that is already part of a completed sequence; once a sequence is achieved by a player or team, it stands. Once a Jack is played, it ends the turn.
The played card then goes face-up into a āDiscardā pile, the player then draws a replacement card from the draw deck, and play passes to the left.
A player may place chips on either of the appropriate card spaces as long as it is not already covered by an opponentās marker chip.
If a player possesses a card which does not have an open space on the game board, the card is considered ādeadā and may be exchanged for a new card. When it is their turn, they place the dead on card on the discard pile, announce they are turning in a dead card, and take a replacement (one card per turn). Then they proceed to play their normal turn.
Each corner of the board has a āFreeā space that all players can use to their advantage. This space acts as if it has a chip of each color on it at all times.
To form rows, chips may be placed vertically, horizontally or diagonally. Each complete row of five (or four and a free corner space) is counted as a sequence. Sequences of the same color may intersect, but only at a single position.
If the draw deck becomes depleted during play, the discard pile is shuffled and drawing begins again.
Sequence rules dictate no table talk or coaching between team members and a precise order in which hands must be played (card, chip, replace card). If a player forgets to replace a card on their turn and if any of the other players points it out then, they cannot make it up in a later one and must continue playing the game with a reduced number of cards.
The game ends when a player or team completes 2 sequences.[3]
Two Sequences in a row:
When two (2) Sequences are required to win they can be in one straight row of nine (9) chips. It is nine and not ten (10), because the rules state that āyou may use any āoneā of the spaces from your first Sequence as part of your second.ā So, a straight line of 9 chips can be formed, in any order and is considered as two Sequences when the 9th chips in a row is placed.
If a Sequence is not announced by the player on creating one then it will not be considered a sequence until the player wishes so.
This is one of my favorite games. Iām new to glowforge⦠am I missing something because I canāt seem to find the file for the sequence board. Any help would be appreciated.
First post.
The two pink and blue outline looking pictures are the files. Drag to your desktop, right click -> save as, or long press and something similar if a touch screen to get it.
Thank you! My brightness was set wrong and I couldnāt see them!
Welcome to the forum. Iām sorry I didnāt see your question earlier, but I see that @wesleyjames was able to answer you. I hope you enjoy the file. If you have any questions, we are all here to help.
Silly question - what materials did you use?
Not silly. I used 3/8" hardboard from Home Depot, smooth on both sides.
this is a fun game. my family enjoys it.
Mine too.
I tried looking, but might have missed it. What did you use to stain the black and red? Thanks so much for your generosity!
I painted them with Rustoleum spray paint while the were still masked, I just weeded the areas that I wanted painted.
And you are most welcome. I am planning to do another one that has the cards in a more symmetrical layout.
