This isn’t supported, sorry.
The best we have to automating things like this is use of colors to set cut/engrave order.
For more info:
It’s worth mentioning that a score is just a low-powered cut. They’re the same thing. You can make this much easier on yourself by using colors and custom settings. Make a “cut” setting at some very low power like 400/15, name it something liker “default score” and it’ll be a score. This saves you a step; you’d only have to click the custom setting called “default score”.
If you get consistent with your color choices (with a custom palette, see above), you can immediately know which step to make a score without even looking.
