I’m trying to etch on a 1.25" piece of oak and can’t seem to figure out what the standard settings are? anyone have suggestions?
Fortunately, there are over 50 existing discussions on this topic (the search function limits results to 50, to avoid wasting bandwidth)…
So just put in the search line-oak settings. You start with the suggestions then change from there!
Welcome!!!
Did you find the settings!? I tried too and didn’t find any results relatable.
As in, nothing that worked for you, or nothing at all?
The search as suggested comes up with settings in the 3rd post, as well as multiple others. You need to read the responses, not just the header as that’s usually a question!
Keep in mind, for engraving the thickness doesn’t matter - so I’d just use the medium red oak PG setting and be sure to use Set Focus before you place your artwork.
Also, a useful post to keep bookmarked:
