A majority of glass colors are made with metals;p
Ruby glass = Gold
green glass = iron
red glass = copper
purple glass = manganese
white glass = was lead
blue glass = cobalt
Much of the borosilicate glass that has a lot of color change in it has germanium dioxide, and if it looks like rainbows inside of clear, it is likely fumed gold or silver.
I won’t be mixing up my own glass colors though, far too much ventilation and torch heat needed to get a good mix;p
the darkness in the purple has turned almost clear (created ticket with primochill its only been 3-4 weeks) also UV’s not mounted cant find a good Velcro to stick on the top alum
Question: I need a new computer for my home to do design work on instead of lugging my PC back and forth. Budget: $2,000. Roll my own or get something already built. I’ve replaced mobos before and all the different parts of a computer but never started from scratch. I have some kick ass acrylic and a Glowforge to manufacture the case.
You will spend less to just buy one but you’ll get exactly what you want to build. So six of, half dozen, other…
If you want a hot video board for Fusion, build.
MOBO - this is a water cooling mobo this is way way more then you need
ASUS ROG Maximus IX Formula LGA1151 DDR4 DP HDMI M.2 Z270 ATX Motherboard
$389.99
Intel Core i7-7700K Kaby Lake Quad-Core 4.2 GHz LGA 1151 91W BX80677I77700K Desktop Processor
$349.99
G.SKILL TridentZ RGB Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 4266 (PC4 34100) Desktop $289.99
gtx1080 - way, way, way more then you need $550
and that’s it that’s a computer just around a 1,500 bucks for really high end pre built for the same specs would cost much more
as you can see I re used my power supply and case and I did not need to get any storage I got SSD’s a while back
you could do the maximus ix code or hero and a 1060 vid
The other option could be a gaming laptop, I have a MSI GT-72 Dominator Pro and I use it for gaming and design, just flawless. Price varies depending on the parts you want on it. Asus has a gaming line too and both are cheaper than Alienware.
I use it at home with an external screen and mouse/keyboard.
Actually, cockpits are more and more like a videogame. The bad thing about it is that the screens show so much information and sometimes is complicated to deal with it, but with proper training it turns out to be a good thing.
Thank you for your kind words. I usually try not to think about the fact that we have the lives of so many people in our care, but so it is.
Exactly what markevans36301 said. I’ve always built my own, but it made more sense when I started. It’s kinda habit. You shouldn’t need $2k unless you’re really into flight simulators or maybe VR. I second Clone, go SSD over HDD whether you buy or build.
I’m assuming you know that the socket type of the CPU you pick has to match the socket on the motherboard.
No kidding. The F-35 has a 360 degree helmet projection system with integrated images from all the sensors. You look through the floor of the aircraft or any direction your head can turn. Can’t really fly it without the helmet. Doesn’t even have a HUD.
Yeah, only problem is the helmets cost about the cost of a high-end Ferrari and are fairly fragile… And because it’s so heavy makes ejection more dangerous and slams into the canopy on high-G turns…
Here is the math from AirForceTimes: If each helmet costs $400,000 and each of the 2,400 F-35s has a pilot, the bottom line cost for helmets is $960 million — not taking into account that pilots retire and are replaced by pilots with different-sized heads.
Yeah, my college roommate’s dad was one of the original test pilots for the apache. He was a former vietnam era huey pilot. Having survived multiple shoot-downs in vietnam and crashes as a test pilot, it seemed one needed a lot of swagger and self-confidence to be getting back into the cockpit… But his “home videos” of test-flights were amazing…
