Silmarillion escutcheon
:grinning: That’s a pretty great looking escutcheon!
One other tip - I’m not sure what orientation you were using on your screen, but if you rotate the image so that the longest axis of the engraving runs horizontally, you will significantly reduce the time it takes, and can sometimes increase the resolution a little bit.
(In other words, it’s better to rotate that top image 90° and print it that way, than it is to leave it the way it is. The orientation won’t matter to the Glowforge software when it interprets it. You can print converted text upside down…doesn’t matter to the software.)
