Do you cut and hot glue a lot of foam board? Do you have a lot of scraps that are too big to toss but too small for what you are doing?
Well, here you go. probably the simplest designs since the circle but very useful for scraping hot glue.
Included is one for sealing the ends of a single piece, one for sealing a stack of two, one for smoothing and removing the excess from inside 90d joints, and finally one for 90d outside.
Make up your own and add them here. Scale the last two as you like, the first two need to remain as is or scaled to your foam board.
Yup, CA, yellow glue, whatever. Hot glue is just my go to for foam board.
You don’t need to limit yourself to cutting these out of foam board either. Once you’ve made all the hold down pins you will ever need start making these out of proofgrade scraps.
I know you to be anything but dense. Some things just don’t click until you see them in use. I’ll see what I can do. Probably as a minute marker in someone else’s video but I’ll get you a demo one way or another.
