I wanted a fob for my spare key, so made a default design (1.25 x 2.25) that art can be added to. This file is not needed for those in the know, but for some that are just getting into this it will be something you can add some art to and burn that may give you some joy.
There is no art inside these base-fob designs, just an outer edge highlight that can be scored or removed.
So add text or art to suit the project and the rest should just happen.
The hole is made for a chicago screw as shown in the picture, and the included TAG (key ring attachment) was made from some flexible 0.030 plastic, but I suppose some thin leather would work just as well.
Fob itself is Proofgrade Draft Board, but can be on anything. I may even play with one or two on 2-color acrylic later, (since the wife saw this and made her thinking face).
No need to make the tag if you are just going to put a key ring or other attachment right into the hole.
I just made the tag to keep it looser on the key ring and use up some of these chicago screws I have piling up.
Samples pictured are a nominal full size and one that I shortened for a smaller graphic.
Both the scallop and curve edge + tag are included in the ZIP
Hope this is helpful for someone. Fobs.zip (3.3 KB)
Actually the same reason here.
It is my spare key for the truck that I give when it is being serviced and it kept disappearing in the drawer.
NOW it is easier to find.
Very nice share. So many times a person new to the Glowforge doesn’t have any software experience, and wants to make something. Everyone can use a key fob!
These are great! I think I’ll make one for my brother for his birthday. Aside from the keyring, what is that hardware stabilizing the hole in the leather?
Thanks for sharing!
That is a chicago screw.
Nice for holding things together (like a clear frame over an engraved item) and also for swivel action if the thickness is right.
With that Draftboard, the thickness (15/64) is such that it swivels easily with the 0.030 plastic used for a tag.
Many thickness options if search for Chicago Screw.
