If you are cutting without the crumb tray, you have to prop the material up so that it falls into the correct engraving zone. The engraving zone is about half an inch from the top of the crumb tray down to where the surface of the crumb tray would be if it were in there.
Trying to engrave on an unsupported item is why your alignment is so far off.
There 's a good tutorial here for how to engrave without the crumb tray:
