Hello! I’m new here, have had my Pro for about a month!
I work with acrylic (proofgrade and Canal Plastics) and I have been trying to get some smooth engraving that is not too deep.
I have tried raising the lines per inch (450), which helps the smoothness some. I have also been defocusing the laser from .125 to .225. When I try lowering the power to say 80 or 60 to get a more shallow engrave it ends up bumpy, compared to the smoothness I get when I use full power.
This looks like it might be a case of raster engraving causing variable heights due to not-quite-black areas. I’m guessing it was hand drawn and scanned in somehow?
Have you tried making a vector out of this and using that instead? You’ll need to make sure there aren’t any voids in the areas you want engraved.
Once you get that set, I’d recommend 340lpi with a 1/16-1/8” defocus. Full power at 2k speed should give you a fairly shallow engrave
I have done such pieces frequently. To get rid of LPI bumpy you need a high LPI, I set the height at 0.3 to 0.5 full power and high speed (1355 LPI , 2500 speed variable …
That only works for rasters. You would still want 1000 and as high in LPI as you can manage. I expect probably 450 or 690. The variable power has 256 power levels, so the larger it is able to spread the results but that is also a raster ability. For acrylic things like grain such as you have to deal with in wood. A height of 0.20 would be better.
