I use wood glue on my projects made of wood. I have recently found a nice easy way to accurately glue in tight spaces with a minimum amount of mess.
I got these at Amazon. They are large enough to be easy to fill plus the glue doesn’t harden in the tube. Just make sure you keep a straight pin in the tip when not in use.
BSTEAN 10ml Syringes 14Ga 1.5 Inch Blunt Tip Needle Storage Caps - Glue Applicator, Oil Dispensing (Pack of 10): AmazonSmile: Industrial & Scientific
I use standard wood glue that I get from Home Depot or Lowes.
The glue is easy to meter out of the tip and easy to control.
For crossreferencing, I love these bottles:
I got a set of these bottles:
They have a very small metal nozzle, allows for extremely precise application of whatever liquids you might need to apply.
I have 3 bottles currently set up: water, denatured alcohol, and wood glue. I put a band of blue electrical tape around the denatured bottle so I can immediately tell it apart from the water.
I might make a danish oil bottle next, might be handy for touchups.
They have really improved my work flow, just the tiny 1/20" dabs of glue in fi…
I keep four of them on my bench at all times: wood glue, white PVA glue, water, and denatured alcohol. I color coded them with tape so I know which is which with water/alcohol.
Your syringe is a pretty good solution too, I may need to try that.
shop
June 23, 2021, 7:57pm
#3
i have those little bottles @evansd2 mentioned as well as one of these:
Product Description
Glue Dispenser, Manual, 4 Oz, For Precision Glue Dispensing, For Use With Wood Glue, Wide Mouth For Easy Fill, Drip less, Spill-less, Easy-Squeeze Bottle, Vacuum Valve To Keep Glue Level High for Easy...
lays down a little more glue at a time (and holds more), but still in a controlled manner.
Well those posts make me feel stupid. I have the syringes and I have the tightbond , and never thought to put them together.
Don’t feel bad, I just did it myself. Makes gluing easier, faster and neater. Plus the glue keeps in the syringe.
rvogt
June 24, 2021, 12:13am
#6
I use those bottles for the liquid glue for my acrylic…works great!
system
closed
July 26, 2021, 2:14am
#7
