It gets there at the first try but that wasn’t that hard to figure out. Made the structure first, then measure the distance to the bottoms of the groves , deconstructed the image taking out the space for wood structure then engrave each pannel on both sides. (Patiently engraved)
I had a question about the continuity of the image thats why i made a miniature first that gave me the answer.
ditto, ditto, ditto–amazing!
And inspiring… I’ve been thinking about etching across a group of tiles for a backsplash–don’t have the structure to account for & remove, but so glad to see such a wonderful example of the idea!!
I suppose that is what I was asking about, what size wood and what technique to put in the groove. I get that hand carving a short bit is better than carving the whole side which is what a router would suggest which is a very interesting idea when it works with the design. I was even thinking of making the rails as 3 pieces of 1/8" wood but 1.5" and 1" wide x 1/8" x 72" wood is hard to come by. It would be great to use wooden hinges, however.
About Wooden hinges
1 1/2 inches bi 3/4 by 72 long ceder pieces tends to distort. So the rigidity of metal hinges is greatly welcomed to maintain them straight. The pieces are routed, but good luck if you opted for 1/8 by 72 inches pieces… though, laminated may be a valid solution…
Boxes .py has an external hinge solution that I have used many times and modified many ways as the solution to different situations.
Bamboo kabab sticks come in 1/8 or 3/16" x 16" lengths so that would be the length of each hinge, and Baltic Birch could have 5 layers per hinge piece and as many as 128 per hinge could be pretty strong. Routed on a 45-degree chamfer the center of the hinge could be right at the corner allowing for 180 degrees of movement.
That is the ideal of course as currently, the long wood and router table are not in the picture, or rather the router table is but the router motor was a rusted mass and I am having trouble finding a proper replacement.
Stunning and inspirational at the same time. This is a truly impressive response to those who ask: “Why a laser cutter/engraver? What do you use it for?”
