This makes me curious about the ability of the machine to engrave on the Y axis instead of the X axis. Its technically possible, but the machine might not be designed to handle Y movement at that speed with the accel/decel.
@dan have you guys looked into this at all? Im just curious about your findings if so
It would be a lot slower to engrave in the Y axis.
For engraving in the X axis, the only thing that has to move is the print head. So it does one line along the x axis, the Y stepper shifts the gantry one line, and it does it again. For lasering along the Y axis the whole gantry has to be shifted.
Makes more sense to orient the file so that the engraving lines appear in the direction you want them to run.
Oh I know, I was just curious if it was something they looked into and the results they got from experimentation. No other laser company has put out anything that engraves that way, which leaves the working bed size reduced. While gf might have a workaround using optical detection, that’s not available to everyone.
Also in the case of someone who has doesn’t have a passthrough, or is using oversized material, they won’t be able to rotate it to get full coverage.
An engrave on the y axis could be feasible, but you’re right that they would have to change the physics of the operation quite a bit.
I need some reassurance. I had a great big gulp when I read 10" depth, which I take it means Y dimension. It downgraded to an “upload” when I read 11.4. However when I started designing I decided to allow for imprecisely sized materials and my outer diameter or Y extent is 300 mm. Which is 11.811 in. The path will be vector cut, and only needs to look right, no function is impinged upon. Reassure me that I can put in a piece that is 12 in wide, cut part of the outline, and then move the material and finish up. Efficiency does not matter, my concern is whether it will be easy to reposition the material accurately enough.
I interpret this as being able to put in a 18" deep piece (in the Y direction, away from the user), so yes, you’d be able to put a piece of material in which you could cut the majority of your 300mm circle.
So yes, you wouldn’t be able to cut the whole perimeter of the circle which it sounds like it doesn’t matter to you.
Furthermore, based upon what I’m reading above, it looks like your circle would look like this:
Where the distance the work area is from the front of the bed area determined by [quote=“dan, post:36, topic:3587”]
The board would be much closer to the front than the back - 1-2" from the edge (I don’t know offhand).
[/quote]
I think that should answer your question?
In addition, if the center of your 300mm had a hole in it, you could rough saw your workpiece and use a jig with a dowel in the middle so that you place your workpiece on the jig, centered on the dowel, then cut as much of the circle you can, stop, rotate your workpiece around the dowel, and finish the cut.
