Thanks, this community is the best!
Thanks!
Thanks again for your generosity!
Would it be an idea to export as pdf?
Cool!
Woke up this morning thinking maybe my preferences got reset last month when I tried to install the newer version of Inkscape on my mac. Didnāt work, so I restored the old version. Checked my settings and they are at 96 dpi. I thought that was the correct setting for interpretation by the GFUI - also for pulling in ai exported files. When I pull your file directly into the GFUI, it does read correctly at 10" sq for the bowl part. I then set the dpi to 72 and opened a fresh copy of your file. The bowl still reads at 8" sq. Moral of the story is - pull your files directly into the GFUI, bypassing Inkscape!
I saved it as a pdf. See if that makes a difference. If it works I will save as both in the future.
New_Square_bowl_10in_1.pdf (65.6 KB)
Success!!! Opened a new GF template file in Inkscape, imported the new pdf file and the square bowl reads 10" sq! That will do the trick for me and I suspect a lot of other people. Thanks for experimenting that with me. Iāll print one later, running another job right now.
Glad it worked out! This is how we learn. I will now post pdfs.
The cherry version! This will be for a friend who has a lot of cherry wood in his house, including Shaker furniture. It will fit in perfectly! Thanks again for the great design - my husband was marveling at it too - and for producing the pdf. I see youāre pdfing all your previous designs - did I say youāre awesome?!!!
Looks great in Cherry! I am glad it worked for you!
Thank you so much for the design. Very kind of you! Very cool that it is dual purpose.
Glad you like it! I love dual design when I can do it.
Really cool. Will try this one tonight Thanks for sharing your design!
Cool canāt wait to see it!
Amazing!!! Thanks for sharing!!
You are welcome!
Thank you so much. I will be using this for food risers and bowls for our company group eventsā¦ ! This is spectacular and I canāt wait to make it! Ditto on everyone elseās āyouāre awesome for doing thisā comments!!!
That you so much! Donāt forget to run 2 additional square leg attachments. I couldnāt get it all to fit on one board.
Will do - thanks again!
