Hello all! Question I want to take a split monogram and add, unite text to it so I can cut as one piece. I can do it in Inkscape. The question is can you do it in photoshop?
Thank you
Thank you
Not if you want to cut. You can certainly make a fancy monogram but it’ll only engrave. Photoshop is primarily raster. For laser work it’s best for adjusting photos for engraving. There are some limited vector path capabilities but the results are messy and you can’t set colors to separate operations.
But if you are sticking with Adobe products, the one you would want to use is Adobe Illustrator, just in case you didn’t already know that that is the Inkscape equivalent.
