Stained Glass with Plexiglass and wood
These are some wood and Plexiglass versions of stained glass
that I have been doing.
I used Baltic Birch, proofgrade maple, and Plexiglass for the frame work.
I used clear, frosted, and mirrored Plexiglass for the inserts.
After a lot of trial and error, I found the best way to keep the inserts
In the frame is to cut an outline of the frame in clear gloss plastic label.
Then place the frame on the label cutout. Remove the protective paper
from one side of the Plexiglass and insert it into the associated opening.
Apply a drop of super glue on the really small pieces to help keep them in place.
You can paint and use the cutouts from the frame to make an all wood
version or just paint and use the frame itself.
I have included the SVG’s.
Settings 1/8 Plexiglass
Speed 145
Power 85
Thick 0.125
LPI 225
Focal Offset 3.17
Keep the protective paper or plastic on both side
of the Plexiglass when cutting.
https://www.estreetplastics.com/
https://www.estreetplastics.com/category-s/146.htm
http://www.eplastics.com/
http://www.eplastics.com/Plastic/samples
OL175CL Clear Gloss Labels
Suncatchers.zip (218.1 KB)
Beautiful! :grinning:
Those are gorgeous!! Book marking the idea!
Wow, great stuff!!!
These are amazing! Nice work!
So awesome!
Somehow I’ve got to work this technique into a fan !
Desperate to get back to Glowfinger, and get these ideas you’ve given me up and running.
Thank you for sharing your workflow.
John :upside_down_face:
Gosh, they came out fantastic! I especially like the tulip one.
Stunning! How did you achieve the effect on the sunflower petals? Was is just the plexi used?
Not sure I understand how the label material works in this process.
They look beautiful!
Those look great.
Me neither. But gorgeous work!
I’ve had that same dragon pinned for ages, been wondering what to do wivit. Thank you for the inspiration!
These are the steps that I use.
1 Cut the frame. (If you are going to make an all wood version save the cutouts)
2 Cut the outline from the clear label material. (The outline is included in the SVG)
3 Peal the backing from the label and place it on a flat surface.
4 Place the frame on the label. (This is the hard part. Try not to touch the sticky
part of the label while placing the frame. On some of the more complex pieces
I split the outline into two pieces to make it easier to place the frame. Now you will
have the frame with the label attached to one side.)
If you are going to use mirrored Plexiglass, Check the orientation of the pieces.
You may have to flip the frame over to match the shape of the pieces before
attaching the label.
Insert the mirror into the frame so that the painted side attaches to the sticky part
of the label. (The shiny side of the mirror should be facing up.)
5 Peal the protective paper or plastic from one side of the Plexiglass. Try not to touch
the unprotected side of the Plexiglass. Place the piece into the frame.
6 Once all the pieces have been placed, flip it over and press the label with your fingers
to insure a good bond. If there are any air bubbles, puncture them with a pin.
7 Remove the protective paper or plastic from the front side of the piece.
Absolutely beautiful.
Some gorgeous pieces here! Thank you for sharing your photos and write up!
