Was having a drink and the barman was putting chocolate on a cocktail (it’s a Jewish restaurant) and he said “I wish I could put a design on it” so lo and behold, I asked for the sizes they needed and …
Let us know how it works. I tried to make some for a coffee shop to add a design to the top of Espresso drinks with coco but it didn’t work out so great. Maybe I just tried with too much detail or didn’t have the proper distribution method of the coco. I should try again. I was using a thin acrylic.
i’ve been thinking about doing some of this for the booze brands i work with, but likely in very thin acrylic or a waterproof mylar (if that exists?) to keep it foodsafe.
i think it would be fine in an application like this. you’re unlikely to put much stress on it unless you’re being sloppy. and it’s cheap enough that you make several just in case.
You are correct, HDPE. My kennels are constructed with large sheets of it and I have used shredded milk jugs melted down to fill screw holes. It absolutely will no cut on a laser. It just melts and flows back into the kerf.
