In that case, you’ve got it even easier. Couple of tutorials you probably ought to read…they explain how to use vector drawing programs to create perfect alignment for your cuts and engraves. (These demo in Illustrator, but you can also use Inkscape or CorelDraw if you are more familiar with those.)
Doing the aligning before saving the file is the way to go. It’s so much more accurate.
This one is handy too:
And there are several in the Tips and Tricks section of the forum that can really speed up the process if you have time to take a look - check the first post by Dan in the category, it’s the door to the Matrix.
