1 5/8"
Oops… brain fart. Nothing to see here…
Wait, without the crumb tray 1 5/8" is ok?? What am I missing?
Brain fart, sorry… fixed it.
So I happen to have a gavel. Took the tray out. Put a piece of paper on the gavel. Used the set focus tool. Took me a few tries to get the beam to fall on the paper. Typed Name in Word and saved as a pdf. Dragged Name onto gavel. Print. 40 seconds
You can do this!
So should I adjust the pre-set basswood settings to begin with?
I would test with paper on the gavel until you are sure of the placement. When you are satisfied with where your engrave is landing, go with a very light power on the wood so that you can sand off if necessary. When you are done testing you can engrave with a higher power and do a second pass if it doesn’t seem deep enough. Just don’t move the gavel once you start.
Meant to upload this shortly after I finished it and I forgot. Thanks to everyone for your suggestions. I made it through and it turned out great. I ended up doing both sides. This is darker than the other side and I did 3 passes for both. I was happy to be able to do this for my friends.
better yet put the engraving on the handle to begin with
because the head is going to be tough
We knew you could do it. Thanks for sharing your success.
