shop
                    January 5, 2019,  9:02pm
              Most users seem to prefer SVGs to send files to the GF. There have been a number of issues with settings exporting ASVGs, most seeming to relate to DPI settings and scaling that come from the original intentions of SVG files being designed as a web graphic format.
PDF files were designed originally to accommodate  print and as well as electronic and, for me have been far more consistent.
So, I’m curious. Why the general preference for SVG? I’m willing to be convinced that it’s a better format for the GF,
              SVG is lightweight and a web standard, PDF is an Adobe standard.
As far as “standard” goes, both have their issues, but overall I prefer the smaller file sizes of the SVG files.
                shop
                    January 5, 2019,  9:49pm
I was curious about this. i just did a save as out of illustrator with 4 files as PDF and as SVG. some PDFs were smaller and some SVGs were smaller. i’m not sure that’s a hard and fast rule. in fact, the PDF was smaller in 3 of the 4 i did. only the escher fish file was larger as PDF.
              Any time Inkscape tries to estimate nodes I get nervous, this would include importing other file formats.  DXFs for example give me terrible results when importing to inkscape.  I prefer to stay in SVG land, it’s native throughout.
I don’t have full acrobat, so editing PDFs in their native habitat isn’t an option for me.  I haven’t been seriously bitten by the PDF->inkscape workflow, but I am not going to fool with it since my SVGs give me zero problems.
                shop
                    January 5, 2019, 10:05pm
                  5
              i can definitely appreciate the issue of not having the full PDF program. can you not open a PDF from inkscape?
              Specifically to Glowforge, SVG means no format changes and less chance for errors/less need for going in and tweaking. It only saves a small amount of time in most cases, but if you’re doing it constantly it adds up.
              Interesting. I’ve got the exact opposite thing going on. My PDFs are always bigger, sometimes by a factor of 10 or more.
Oh, and one more “advantage” if you will of an SVG is I can view source and make tweaks with something as simple as notepad. This obviously isn’t something everybody would want to do though.
In the end, whatever works for you is the right approach. There is no right or wrong as far as the GF is concerned, it takes both.
The only modification I’ve made to my work flow was adapting to the newest AI CC interface last year. I’d just learned the old interface (somewhat) when Adobe changed things. I’m quite fond of the new interface now, and have learned so much more since last year at this time.
                shop
                    January 5, 2019, 10:33pm
                  8
hrm. i could work purely in PDF files if i want, but that may be based on me using Illustrator.  regardless, i’m not sure i would work in a purely SVG world. SVGs don’t support a lot of what a native file format supports (PDF does for illustrator if you keep the “preserve illustrator editing” box when you save). i wouldn’t want to lose things like layers or brushes or anything like that. so i always have a native file for any project i work in.
make sure you have your PDF export files set up to save smaller files. from illustrator, what i mentioned above is a big part of that. unchecking that “preserve illustrator editing” box will make a much smaller file most of the time.
                chris1
                    January 5, 2019, 10:41pm
                  9
              Use what you like!
But… I just went into Illustrator and drew a 1x1in circle positioned at 1,1 on a Glowforge-sized artboard, then saved it as both an SVG and a PDF.  The SVG file contains this:
<svg id="Layer_1" data-name="Layer 1" xmlns="http://www.w3.org/2000/svg" width="20in" height="12in" viewBox="0 0 1440 864">
  <title>Artboard 1</title>
  <circle cx="108" cy="108" r="36" fill="#fff" stroke="#231f20" stroke-miterlimit="10"/>
</svg>
and the PDF contains this:
%PDF-1.6\r%‚„œ”\r
1 0 obj\r<</Metadata 2 0 R/OutputIntents[<</DestOutputProfile 5 0 R/Info(U.S. Web Coated \\(SWOP\\) v2)/OutputCondition()/OutputConditionIdentifier(CGATS TR 001)/RegistryName(http://www.color.org)/S/GTS_PDFX/Type/OutputIntent>>]/Pages 3 0 R/Type/Catalog>>\rendobj\r2 0 obj\r<</Length 24014/Subtype/XML/Type/Metadata>>stream\r
<?xpacket begin="Ôªø" id="W5M0MpCehiHzreSzNTczkc9d"?>
<x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="Adobe XMP Core 5.6-c145 79.163499, 2018/08/13-16:40:22        ">
   <rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#">
      <rdf:Description rdf:about=""
            xmlns:dc="http://purl.org/dc/elements/1.1/"
            xmlns:xmp="http://ns.adobe.com/xap/1.0/"
            xmlns:xmpGImg="http://ns.adobe.com/xap/1.0/g/img/"
            xmlns:xmpMM="http://ns.adobe.com/xap/1.0/mm/"
            xmlns:stRef="http://ns.adobe.com/xap/1.0/sType/ResourceRef#"
            xmlns:stEvt="http://ns.adobe.com/xap/1.0/sType/ResourceEvent#"
            xmlns:illustrator="http://ns.adobe.com/illustrator/1.0/"
            xmlns:xmpTPg="http://ns.adobe.com/xap/1.0/t/pg/"
            xmlns:stDim="http://ns.adobe.com/xap/1.0/sType/Dimensions#"
            xmlns:xmpG="http://ns.adobe.com/xap/1.0/g/"
            xmlns:pdf="http://ns.adobe.com/pdf/1.3/"
            xmlns:pdfxid="http://www.npes.org/pdfx/ns/id/"
            xmlns:pdfx="http://ns.adobe.com/pdfx/1.3/">
         <dc:format>application/pdf</dc:format>
         <dc:title>
            <rdf:Alt>
               <rdf:li xml:lang="x-default">Untitled</rdf:li>
            </rdf:Alt>
         </dc:title>
         <xmp:MetadataDate>2019-01-05T17:30:54-05:00</xmp:MetadataDate>
         <xmp:ModifyDate>2019-01-05T17:30:54-05:00</xmp:ModifyDate>
         <xmp:CreateDate>2019-01-05T17:30:54-05:00</xmp:CreateDate>
         <xmp:CreatorTool>Adobe Illustrator CC 23.0 (Macintosh)</xmp:CreatorTool>
         <xmp:Thumbnails>
            <rdf:Alt>
               <rdf:li rdf:parseType="Resource">
                  <xmpGImg:width>256</xmpGImg:width>
                  <xmpGImg:height>256</xmpGImg:height>
                  <xmpGImg:format>JPEG</xmpGImg:format>
                  <xmpGImg:image>/9j/4AAQSkZJRgABAgEASABIAAD/7QAsUGhvdG9zaG9wIDMuMAA4QklNA+0AAAAAABAASAAAAAEA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</xmpGImg:image>
               </rdf:li>
            </rdf:Alt>
         </xmp:Thumbnails>
         <xmpMM:InstanceID>uuid:c6b25b21-46fe-0049-92d7-a92ed914c007</xmpMM:InstanceID>
         <xmpMM:DocumentID>xmp.did:1c158e11-8b55-4715-a727-8b1fb98bf0d2</xmpMM:DocumentID>
         <xmpMM:OriginalDocumentID>uuid:5D20892493BFDB11914A8590D31508C8</xmpMM:OriginalDocumentID>
         <xmpMM:RenditionClass>proof:pdf</xmpMM:RenditionClass>
         <xmpMM:VersionID>1</xmpMM:VersionID>
         <xmpMM:DerivedFrom rdf:parseType="Resource">
            <stRef:instanceID>xmp.iid:0999d516-947a-4a39-a8de-004c50b8460d</stRef:instanceID>
            <stRef:documentID>xmp.did:0999d516-947a-4a39-a8de-004c50b8460d</stRef:documentID>
            <stRef:originalDocumentID>uuid:5D20892493BFDB11914A8590D31508C8</stRef:originalDocumentID>
            <stRef:renditionClass>proof:pdf</stRef:renditionClass>
         </xmpMM:DerivedFrom>
         <xmpMM:History>
            <rdf:Seq>
                  <stEvt:action>saved</stEvt:action>
                  <stEvt:instanceID>xmp.iid:545a3f0d-0430-4406-83f4-40e55ad0cde7</stEvt:instanceID>
                  <stEvt:when>2019-01-05T17:27:01-05:00</stEvt:when>
                  <stEvt:softwareAgent>Adobe Illustrator CC 23.0 (Macintosh)</stEvt:softwareAgent>
                  <stEvt:changed>/</stEvt:changed>
               </rdf:li>
                  <stEvt:instanceID>xmp.iid:1c158e11-8b55-4715-a727-8b1fb98bf0d2</stEvt:instanceID>
                  <stEvt:when>2019-01-05T17:29:59-05:00</stEvt:when>
               </rdf:li>
            </rdf:Seq>
         </xmpMM:History>
         <illustrator:StartupProfile>Print</illustrator:StartupProfile>
         <xmpTPg:HasVisibleOverprint>False</xmpTPg:HasVisibleOverprint>
         <xmpTPg:HasVisibleTransparency>False</xmpTPg:HasVisibleTransparency>
         <xmpTPg:NPages>1</xmpTPg:NPages>
         <xmpTPg:MaxPageSize rdf:parseType="Resource">
            <stDim:w>20.000000</stDim:w>
            <stDim:h>12.000000</stDim:h>
            <stDim:unit>Inches</stDim:unit>
         </xmpTPg:MaxPageSize>
         <xmpTPg:PlateNames>
            <rdf:Seq>
               <rdf:li>Black</rdf:li>
            </rdf:Seq>
         </xmpTPg:PlateNames>
         <xmpTPg:SwatchGroups>
            <rdf:Seq>
                  <xmpG:groupName>Default Swatch Group</xmpG:groupName>
                  <xmpG:groupType>0</xmpG:groupType>
               </rdf:li>
                  <xmpG:groupName>Glowforge</xmpG:groupName>
                  <xmpG:groupType>1</xmpG:groupType>
                  <xmpG:Colorants>
                     <rdf:Seq>
                           <xmpG:swatchName>1 Black</xmpG:swatchName>
                           <xmpG:type>SPOT</xmpG:type>
                           <xmpG:tint>100.000000</xmpG:tint>
                           <xmpG:mode>RGB</xmpG:mode>
                           <xmpG:red>0</xmpG:red>
                           <xmpG:green>0</xmpG:green>
                           <xmpG:blue>0</xmpG:blue>
                        </rdf:li>
                           <xmpG:swatchName>2 Dark Blue</xmpG:swatchName>
                           <xmpG:blue>255</xmpG:blue>
                        </rdf:li>
                           <xmpG:swatchName>3 Dark Green</xmpG:swatchName>
                           <xmpG:green>100</xmpG:green>
                        </rdf:li>
                           <xmpG:swatchName>4 Navy Blue</xmpG:swatchName>
                        </rdf:li>
                           <xmpG:swatchName>5 Bright Green</xmpG:swatchName>
                           <xmpG:green>255</xmpG:green>
                        </rdf:li>
                           <xmpG:swatchName>6 Aqua Blue</xmpG:swatchName>
                        </rdf:li>
                           <xmpG:swatchName>7 Brown</xmpG:swatchName>
                           <xmpG:red>100</xmpG:red>
                        </rdf:li>
                           <xmpG:swatchName>8 Purple</xmpG:swatchName>
                        </rdf:li>
                           <xmpG:swatchName>9 Lime Green</xmpG:swatchName>
                        </rdf:li>
                           <xmpG:swatchName>10 Red</xmpG:swatchName>
                           <xmpG:red>255</xmpG:red>
                        </rdf:li>
                           <xmpG:swatchName>11 Magenta</xmpG:swatchName>
                        </rdf:li>
                           <xmpG:swatchName>12 Orange</xmpG:swatchName>
                        </rdf:li>
                           <xmpG:swatchName>13 Yellow</xmpG:swatchName>
                        </rdf:li>
                     </rdf:Seq>
                  </xmpG:Colorants>
               </rdf:li>
            </rdf:Seq>
         </xmpTPg:SwatchGroups>
         <pdf:Producer>Adobe PDF library 15.00</pdf:Producer>
         <pdf:Trapped>False</pdf:Trapped>
         <pdfxid:GTS_PDFXVersion>PDF/X-4</pdfxid:GTS_PDFXVersion>
         <pdfx:GTS_PDFXVersion>PDF/X-4</pdfx:GTS_PDFXVersion>
      </rdf:Description>
   </rdf:RDF>
</x:xmpmeta>
<?xpacket end="w"?>\rendstream\rendobj\r3 0 obj\r<</Count 1/Kids[6 0 R]/Type/Pages>>\rendobj\r6 0 obj\r<</BleedBox[0.0 0.0 1440.0 864.0]/Contents 7 0 R/CropBox[0.0 0.0 1440.0 864.0]/MediaBox[0.0 0.0 1440.0 864.0]/Parent 3 0 R/Resources<</ExtGState<</GS0 8 0 R>>>>/TrimBox[0.0 0.0 1440.0 864.0]/Type/Page>>\rendobj\r7 0 obj\r<</Filter/FlateDecode/Length 138>>stream\r
H\M^I*‰2P∞03Q0411P–\^E±\M^JRπ¬\^UÚ\M^@¬\^P\M^XÕ••Ô\^^l\240\M^P^ÃU®`\b\^V1\^D)V075SHŒ\^E+\^C\M^Q∫\M^F\M^Vz\^V\^VF@⁄Lœ––BA◊ÿ\f\M^N\M^SπtMM!≤ \^Qs#\M^Dj €\0$\^O§aBP•PΩ\^PÌPC\M^A\^\\^C\M^X:\^C∞∆4Æ@®K\r\^Uº\a•\v3∏\M^B\M^An\f‰\^B\b0\0√ë\M^QC˙\rendstream\rendobj\r8 0 obj\r<</AIS false/BM/Normal/CA 1.0/OP false/OPM 1/SA true/SMask/None/Type/ExtGState/ca 1.0/op false>>\rendobj\r5 0 obj\r<</Length 557168/N 4>>stream\r
\0\b\M^@pADBE\^B\^P\0\0prtrCMYKLab \a–\0\a\0\^Z\0\^E\0)\0005acspAPPL\0\0\0\0ADBE\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0ˆ÷\0\^A\0\0\0\0”-ADBE\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0
desc\0\0\0¸\0\0\0tcprt\0\0\^Ap\0\0\0+wtpt\0\0\^A\M^\\0\0\0\^TA2B0\0\0\^A∞\0\0¢\^FA2B2\0\0\^A∞\0\0¢\^FA2B1\0\0£∏\0\0¢\^FB2A0\0\^AE¿\0\^B8¥B2A1\0\^C~t\0\^B8¥B2A2\0\^E∑(\0\^B8¥gamt\0\aÔ‹\0\0\M^P\M^Qdesc\0\0\0\0\0\0\0\^ZU.S. Web Coated (SWOP) v2\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0text\0\0\0\0Copyright 2000 Adobe Systems, Inc.\0\0XYZ \0\0\0\0\0\0µZ\0\0ºg\0\0\M^R0mft2\0\0\0\0\^D\^C	\0\0\^A\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\^A\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\^A\0\0\^A\0\0\^B\0\0\^B$\^D\^]\^E⁄\ai\bŸ
6\v\M^E\f«\rˇ\^O1\^P^\^Q\M^K\^R∑\^S‚\^U\v\^V2\^WW\^Xy\^Y\M^X\^Zµ\^[“\^\Ô\^^%\^_Y \M^G!≤"⁄#ˇ%#&D'f(\M^F)ß*«+Ë-\b.(/H0i1\M^I2¶3¬4fi5˚7\^X859Q:m;\M^I<•=¬>fi?¯A\^QB)CBD\\EuF\M^OG©H√I›J˜L\^RM,NCOYPoQ\M^FR\M^\S≤T…UflVˆX\rY#Z:[Q\\f]x^\M^J_\M^[`≠aæbœc‡dÒf\^Bg\^Rh#i3jBkRl^mgnqozp\M^Cq\M^Lr\M^Ts\M^\t£u™v±w∑xΩy√z»{Õ|Œ}Õ~Ã\^?ÀÄ\M^@…Å\M^A«Ç\M^B≈É\M^C\M^D\M^Dø\M^Eª\M^F∑\M^G≥\M^HÆ\M^I©\M^J§\M^K\M^^\M^L\M^X\M^M\M^Q\M^N\M^F\M^O{\M^Pp\M^Qd\M^RX\M^SL\M^T@\M^U3\M^V&\M^W\^Y\M^X\f\M^Xˇ\M^YÚ\M^Z‰\M^[÷ú\M^\»ù\M^]ª\M^^≠\M^_\M^_\240\M^N°|¢j£W§E•3¶ ß\^N߸®Í©◊™™≈´´≥¨°≠\M^OÆ}Øk∞Y±G≤6≥$¥\^Rµ\0µÌ∂⁄∑∑»∏∏µπ£∫\M^Pª~ºkΩYæGø5¿"¡\^P¡˛¬Ï√⁄ƒ«≈µµ∆££«ë\M^Q»~…l YÀDÃ.Õ\^XŒ\^AŒÎœ’–ææ—ßß“ê\M^P”y‘a’I÷1◊\^Xÿ\0ÿÊŸÕ⁄≤≤€ò\M^X‹}›bfiGfl,‡\^P‡Ù·ÿ‚ª„\M^^‰{ÂWÊ3Á\^NÁËË¡È\M^ZÍqÎHÏ\^]ÏÌ√Ó\M^VÔvUÒ3Ú\^OÚÍÛ√Ù\M^\ısˆI˜\^^˜Û¯∆˘\M^U˙a˚)˚θ߽\\˛\v˛¥ˇZˇˇ\0\0\^AË\^Cß\^E,\^F\M^D\aø\bÁ
\^D\v\^V\f\^\\r\^^\^N\^\\^O\^Y\^P\^W\^Q\^T\^R\^P\^S\v\^T\^D\^T¸\^UÛ\^VÊ\^Wÿ\^XÃ\^Y÷\^Zfi\^[·\^\·\^]fl\^^€\^_÷ —!À"ƒ#æ$∏%≥&Æ'™(¶)¢*\240+\M^^,\M^]-\M^Z.\M^U/\M^Q0\M^M1\M^I2\M^F3\M^C4\M^A5\^?6\^?7\^?8\M^@9\M^B:\^?;~<|=|>|?}@\^?A\M^BB\M^EC\M^ID\M^ME\M^RF\M^XG\M^ZH\M^[I\M^]J\M^_K£L¶M™NØO¥P∫Q¿R«SŒT’U◊VŸW€XfiY‡Z„[Á\\Í]Ì^Ò_ı`¯a¸c\0d\^Ce\^Aeˇf¸g˙h¯iıjÛklÓmÎnËoÂp·qfir⁄s÷tÕu√vπwØx•y\M^[z\M^P{\M^E|z}o~d\^?X\M^@M\M^AA\M^B5\M^C)\M^D\^\\M^E\^P\M^E˛\M^FÌ\M^G€à\M^H â\M^I∏\M^J¶\M^K\M^U\M^L\M^C\M^Mq\M^N`\M^ON\M^P=\M^Q,\M^R\^[\M^S
\M^S˙\M^TÈ\M^U\^F\V\M^V…ó\M^W∫\M^Xß\M^Y\M^S\M^Z\M^@\M^[m\M^\Z\M^]H\M^^6\M^_%\240\^T°\^D°ı¢Ê£ÿ§§ ••Ω¶±ß¶®\M^[©\M^Q™\M^G´\^?¨w≠oÆgØ`∞Z±T≤O≥L¥IµF∂E∑D∏EπF∫HªJºNΩRæWø]¿c¡j¬r√{ƒÑ\M^D≈ä\M^J∆ê\M^P«ñ\M^V»ù\M^]…•• ≠≠\^B\√∂∂ÃøøÕ»Œ“œ‹–Ê—Ò“˚‘\^F’\^R÷\^^◊*ÿ7ŸD⁄Q€^‹k›yfiÜ\M^F\a\√î\M^T‡\M^\·¢‚®„≠‰≤Â∂Ê∫ÁΩË¿È√Í‘ÎÂÏıÓ\^DÔ\^R Ò,Ú8ÛCÙNıYˆc˜j¯n˘o˙l˚d¸V˝D˛/ˇ\^Wˇˇ\0\0\^B\^E\^Cÿ\^Eh\^F∆\b\^F	2
R\ve\fr\rx\^Nz\^Oz\^Pz\^Qy\^Ru\^Sp\^Th\^U^\^VR\^WE\^X7\^Y)\^Z4\^[=\^\@\^]?\^^:\^_4 ,!#"\^Y#\^O$\^D$˘%Ó&„'ÿ(Ã)¡*∂+´,\M^_-\M^S.\M^G/|0p1d2Y3M4A566+7!8\^V9\v:\0:ˆ;Ì<„=€>”?À@ƒAΩB∑C≤D¨E¶F°G\M^\H\M^WI\M^TJ\M^PK\M^NL\M^KM\M^JN\M^IO\M^HP\M^HQ\M^IR\M^HS\M^HT\M^HU\M^HV\M^IW\M^JX\M^KY\M^MZ\M^O[\M^Q\\\M^S]\M^V^\M^X_\M^[`\M^]a\M^_b\240c°d£e§f¶gßh®i©j™k™l´m´n´o´p©q®r•s£t\240u\M^]v\M^Yw\M^Ux\M^Qy\M^Lz\M^G{\M^B||}v~o\^?i\M^@a\M^AZ\M^BQ\M^CH\M^D>\M^E5\M^F+\M^G!\M^H\^W\M^I\f\M^J\^B\M^J˜\M^KÌ\M^L‚\M^M\^F\^N\M^N\^C\O\M^O√ê\M^Pπ\M^QØ\M^R•\M^S\M^\\M^T\M^R\M^U\M^I\M^V\M^@\M^Wx\M^Xp\M^Yj\M^Zc\M^[^\M^\Y\M^]U\M^^R\M^_P\240O°O¢P£R§U•Y¶_ßf®n©x™\M^B´\M^N¨\M^\≠´ÆªØÃ∞∞\a\√±±Û≥	¥ µ8∂Q∑l∏\M^Gπ§∫¬ªª·Ω\^Aæ!øC¿e¡\M^G¬™™√ŒƒÒ∆\^U«9»^…Ç\M^B ¶¶À ÃÌŒ\^Pœ2–T—t“î\M^T”≤≤‘œ’Î◊\^Fÿ\^^Ÿ6⁄L€a‹t›á\M^Gfiò\M^X\a\√ß߇≥·æ‚«„Õ‰—“ʖÁÃ˃È∫ͨÎ\M^[Ï\M^GÌoÓXÔ\\[ÒVÚLÛ=Ù*ı\^Rıˆˆ÷˜≥¯\M^M˘b˙/˙Ù˚±¸f˝\^Q˝≥˛M˛·ˇqˇˇ\0\0\^AŸ\^C\M^M\^E	\^FT\a\^?\b\M^V	°
§\v\M^_\f\M^S\r\M^B\^Np\^O_\^PL\^Q7\^R!\^S	\^S\^T÷\^Uª\^V\M^_\^W\M^C\^X\M^A\^Y}\^Zt\^[f\^\U\^]A\^^,\^_\^W \0 Í!”"Ω#¶$\M^P%z&d'N(9)%*\^P*˝+Í,◊-ƒ.±/\M^^0\M^L1y2g3U4D526"7\^Q8\^A8Ò9‚:”;ƒ<µ=¶>\M^X?\M^J@}AoBbCUDIE<F0G#H\^WI\vIˇJÛKËL‹M–N≈OπP≠Q°R\M^US\M^HTzUmV_WQXCY5Z&[\^X\\	\\˙]Î^‹_Ã`Ωa¨b\M^[c\M^IdxeffTgBh0i\^^j\vj¯kÂl“mæn™o\M^Vp\M^BqlrVs@t)u\^Ru˚v‰wÕx∂y\M^^z\M^F{n|V}>~%\^?\r\^?Ù\M^@€Å\M^A\M^B\M^B®\M^C\M^M\M^Dr\M^EW\M^F;\M^G \M^H\^E\M^HÍ\M^Iœä\M^J≥\M^K\M^X\M^L}\M^Mb\M^NG\M^O-\M^P\^R\M^P¯\M^Qfií\M^Rƒì\M^S™\M^T\M^Q\M^Ux\M^V`\M^WG\M^X/\M^Y\^X\M^Z\^A\M^ZÍ\M^[\^E\^\\M^\ø\M^]™\M^^\M^V\M^_\M^C\240q°_¢O£?§0•"¶\^Uß\bß˝®Û©Í™‚´€¨¨’≠≠–ÆÆ\^B\√ØØ«∞∞ƒ±±¬≤≤¡≥¡¥¬µµ≈∂∂»∑∑\^C\x∏”ππ€∫∫„ªÌº¯æ\^Dø\^Q¿ ¡0¬@√Rƒf≈z∆è\M^O«¶¶»ææ…÷ ÒÃ\fÕ*ŒGœc–Ä\M^@—ü\M^_“øø”‡’\^C÷'◊Lÿs\^F\[\M^[⁄ƒ€Ô›\^ZfiFfls‡°·œ„\^B‰MÂ\M^YÊÁË6È\M^FÍÿÏ+Ì\M^@Ó◊1Ò\M^P
Well, actually it contains a lot more than that, but the forum won’t let me paste the full megabyte of crap, so I had to truncate it at 30k.
I’m not making a file size argument, BTW, I couldn’t care less how big it is. It’s about the ridiculous complexity and impenetrability of PDF. Whatever is in there, it’s a lot more than a laser cutter needs to make a circle.
                shop
                    January 5, 2019, 10:52pm
                  10
              not sure how you ended up with a full megabyte. i saved a 1" circle as PDF and it was 49k. granted, that’s bigger than the 1k circle from SVG.
my settings: started with high quality print, adjusted to Acrobat 8 compatibility and turned off preserved editing and got 49k.
did it again at “illustrator default” and it was 739k. but that is essentially a compressed illustrator file, as it contains things like layers and other illustrator features in it. it’s a lot of unnecessary data to upload to the GFUI for sure, but you don’t need to use those settings when you export.
the main reason i have advocated in the past for PDF is because, well, it just doesn’t give as many print errors. hell, you don’t even need to convert text to outlines first because the PDF handles the fonts for you, even in the GFUI.
i agree with the “use what you like” philosophy, neither is wrong. i was just trying to understand why users predominantly use SVG instead of PDF.
i’m sure some of why i use PDFs is because i’ve used it for almost two decades to send print files to printers.
                chris1
                    January 5, 2019, 10:59pm
                  11
              Again, I don’t care about the file size, but I do care about simplicity and directness. The SVG is not 1k, it’s 248 bytes, and nearly all of them are relevant to the task at hand.
I’m impressed that the Glowforge app can make use of PDFs at all, but I personally dislike their convoluted and opaque nature.
                shop
                    January 5, 2019, 11:03pm
                  12
              well, PDFs have to be able to do a lot more than an SVG will do, so i’m not surprised that the overhead to make that work is more. not trying to defend adobe or say that the format couldn’t be more transparent, but the capabilities of a PDF are light years ahead of what SVG can do. could it be less convoluted and still accomplish everything it needs to? i can’t say, i’m not a coder, but ut’s a much more robust file format than SVG is, we just don’t need 99% of that for the GFUI.
that’s not intended as a ding on the SVG format. PDF was designed to do a lot more and SVG was designed to be a simpler structure. it is what it is.
              I’m not a big Tech head when it comes to file formats I always just use whatever I started with and have never had a problem with either. Inkscape does PDF just fine.
                hansepe
                    January 5, 2019, 11:51pm
                  14
As I’ve now seen discussed after you posted the quote above, I’ve never bothered optimizing the PDF output since SVG has worked from the beginning for me. I will probably go tweak them now though just because…
                system
                    February 7, 2019,  1:51am
                  15
