The project production continues (It pays to design in advance to receiving the machine)
This is a Tea Boat, designed to receive water from spills or cleaning in the tea process. I already had one, but it was all wood and started to warp from humidity. So I designed a new one.
I decided to have a simple finger joint with the thickness of the material has the teeth height, but I didn’t realized the acrylic wasn’t exactly 1/8" but a bit thinner and so, the nesting is a bit too tight.
I have a Hexagonal design thing and so, I had to include it. Which is why the holes are hexagonal.
The 1/8" cover is a bit light for my cast iron pot, but it holds for now. Also the inlay isn’t graceful/ perfect (I hid a lot of mistakes there) but I would need to better beta test before for the next one)
The only thing missing is a good coat of varnish for protection.
Edit 2019-10-24: Did a varnish coat, but the top layer is creeping due to my cast iron tea pot. Would need a middle support or a thicker material. Also, the inlay works but isn’t the best idea in this.
It is. Bought from David’s tea. I first bought a set but they had pulled it out of collection by the time I wanted more. Then I broke one. I tried to buy some elsewhere but the volume ( which I really like) isn’t standard. Last Fall, they brought it back. Bought 8 (4 + spares) not to be caught searching for them.
Without some fixed size tool getting them even similar is a real challenge. Folks always make a joke about glass blowers (just don’t suck in) but that is exactly what is needed that the outside is made with a thick hot part across the top. But unless there is a tool to set the shape the pressure differences try to make a sphere, but a tool leaves a mark so that too is a problem. A search for what is very likely very slight circular variations would tell a lot, even having a very polished tool would likely leave something.
You clearly know more about glass then me. What i meant was that usual double wall glass are either espresso size (half what I have) or coffee mug size (1.5-2 times what I have).
