here’s a great big smooch
for this share! Thank you.
when offsetting a path the accuracy of that offset can be dependent on the number of nodes you have in your design … process of offsetting can introduce errors
I tested this on Affinity Designer, with the particular curve used in the jigsaw template. Indeed there was some error, as expected. As far as I could tell, with a nominal offset of 0.0025", the error ranged from zero up to 0.00003". Fortunately, quite within tolerance for this particular application.
Adding extra nodes (again, in Affinity Designer with this particular curve) didn’t make much difference.
