I decided I wanted to make a custom domino set in 1/4" clear acrylic. So a little bit of time in illustrator later and I have a file to test for settings.
Attempt 1 didnt cut through till I reran it and got some serious flash back
Attempt 2 had the same problem but my tweaked engraving settings worked better
Attempt 3 had the best engravings but the worst cuts
And attempt 4 had the best cuts but still a little bit of flashback that I need to get rid of on it.
The graphic needs a few changes too but that is proving much easier than nailing down this cut settings
