Hi there! Is there a way you can create multiple lines with the text tool without have to create a new line each time? When I hit return to create another line it does not let me.
I don’t think it’s possible.
If you need to do a bunch of lines of text, you’re probably better off hopping into Inkscape or Illustrator.
Or use my favorite tool:
https://wmd-glowforge.github.io/text2vector/
This will actually spit out text that is a single stroke (i.e., not outlined text, but a single line for each stroke of the letter). The advantage is this text can be scored, which is much, much faster than engraving it.
Good luck!
Wow, bookmarking this baby for sure! Thanks for sharing.
I have learned so much from reading other people’s posts.
That’s the massive power of the forum.
