Glad it worked out. I was beginning to think you got a GlowFrog
I’ve had these strange things happen to me on my CNC plasma cutter as well. Text blocks and CAM programs are really strange. I’ve had things look completely normal in the preview, simulation, toolpaths, etc. but the cuts happen in a completely different way. I use Mastercam for Solidworks though, that’s always strange.
Sounds like this is far more common than I knew. I hadn’t experienced anything like that prior. So I learned something.
My only CNC device so far, a vinyl cutter, picks its next cut like a drunk barber. It appears to be total chaos and maximum inefficiency.
In printing these tokens, there are 77 of them on a 17" sheet of proofgrade. In the cut it will skip one in the middle and a couple on an end, but returns to finish. (it doesn’t skip anything in the engrave)
Something else to be aware of regarding bed image, is the distortion from the wide-angle lens. It freaked me out. Let me explain.
For this file both the front and back images are nested together, with different colors so the UI recognizes them as separate operations. The workflow is to ignore the back and engrave and cut the front, then open the lid and flip all the tokens over in the hole they were cut from so the tokens are all registered for the next engrave - then ignore the front and the cut and engrave the back.
Whenever the lid is opened and closed the camera re-images the bed. looking at the new bed image the design to be engraved is offset to the left (maybe 1/8") on the left side, and to the right on the right side by the same amount. The middle looks correct.
looking like it is going to engrave slightly off, I was afraid (after a two hour engrave on the front) to press the button for fear it would be misaligned and trash the job. It didn’t, and printed perfectly.
Took me a while to figure it out, of course that was after I bugged it to support and wasted their time. (they are really nice patient people)
When I open the file the image is placed by the software, (no distortion) but the bed image taken after the lid is closed is a camera image.
So the distortion is a function of the wide-angle lens, not misbehaving software as I had thought. No fault there, the camera is doing just what it was designed to do - identifying the sticker on the material, and enabling calibrating by locating the
logo on the head right under it. Right under it is key. For tracing or image sizing/placement, work directly under the camera for best results.
In a situation like this, don’t worry about the distortion in the image. If nothing has moved, the machine will print exactly where it should.
Frustrated and disappointed for sure, but don’t get mad. ( they are really nice people) More often than not my perceived problem with the machine has turned out to be either an issue with my file, or another failure on my part. Did I mention how nice those people are?
When I ran off my sheet of tokens, the GF played hop-scotch all over the bed for both the engraves and the cut layers, but eventually filled everything in. Pretty nerve-wracking on a 3-hour job. Luckily
I had seen this behavior before while creating something that had hundreds of short scores around a circle. Had pretty much the same reaction as Tom the first time around. ![]()
Wow. So that works for your flipping them over. How the heck would one account for the distortion when working with a bed full of pre-cut objects? So let’s say I had a bunch of coasters, or pencils, or pre-cut tokens. And I empty the bag of tokens on the bed willie-nillie, as it were. They take up the entire bed. And I drag my images onto each of them manually. Wanting my image to be centered on my token. How the heck can ya plan for that on the edges?
Yes, the motion planning is a mystery to me. I noticed when cutting tabbed boxes it cut around the pieces in an unbroken line one at a time. Next run I positioned the pieces closer to conserve material and it would jump to an adjacent line close to it, so there it seemed like proximity played a role - but not with the tokens. very close together, but would ignore one and come back at the end to finish.
Maybe the geometry figures in, the tokens being round and the boxes being square…
Thanks again Dennis. Mallory commented on what a nice guy you were.
You would want to avoid having a bed full of individual items randomly scattered and have to position an image on them one at a time freehand. Serious time-killer and questionable accuracy.
Much easier and much quicker to have all the designs in a single file rather than futz with them individually, and for accuracy use a jig to register the material on the bed. In my case it was the sheet they were cut from. @marmak3261 made a jig for his pencils from cardboard if I remember. (BTW he was a huge help in my project)
He hooked me up with the images of each side in a different color nested in a single file. You engrave one side and cut them ignoring the other color (side), then open the lid, flip them and engrave the side you previously ignored. That way you only load one file. I highly recommend that workflow for the sake of ease, time and accuracy.
For just a few items using the ‘add Artwork’ feature, I would work in the center of the bed as close to the camera as possible for dragging and placing images freehand. The center line of the bed doesn’t suffer the distortion nearly as bad as the left/right edges. When scaling a cut to fit an existing shape I work right under the camera.
Edit; have you heard anything from support yet?
