For those who don’t read Hackaday:
Some experiments with a laser-cut mortise and tenon joint:
Elegant design! ![]()
Ooooo…
This makes me want to run out and design something right now. Tapping that wedge in just looks so satisfying!
Thank you for sharing!
Saw that, too! Interesting idea!!lots of potential.
that looks pretty cool for the right project. saved a copy of that PDF out for later.
I think you and I might be a lot alike…I felt the same way when I saw that. ![]()
interesting… don’t have an application for it just yet. but hey one never knows.
I had an idea that needs an SVG of an American flag. searched around here and found the perfect one.
so I figure I’ll be searching for this thread some day in the future.
Intriguing!
Love that concept…now to apply it!
The wedge, mortise and tennon may well be man’s oldest piece of joinery, but I sure like this take on it.
I really wonder how this would work in acrylic?
Anything to use less glue is a plus.
Ooh! I wonder if this would be even more permanent with the addition of @dan’s serrated tabs
Gonna have to figure out something to test it with ![]()
I was thinking the same thing!
The write-up mentions something similar as a possible future evolution.
I’m pretty sure light serrations would help in certain materials. Like acrylic.
If anyone else wants to give this a shot before I get around to it…
Okay, I had to know. You know, for science.
Medium draftboard: Holds but the pin tends to go off center and split. Ify
1/8 Baltic Birch: Holds but the pin tends to go off cent and split. Ify
1/4 plywood: didn’t work at all as the kirf was too big
Thick draftboard: Pin goes off center (is this just me?) but shows the most promise, nice joint after a little tweaking
1/4 acrylic: snapped, so total failure
Thick cheery proofgrade: Best of the bunch! the outer plys hold everything together and it would be totally possible to make a great joint with this. For the win!
Thanks for sharing your testing @markevans36301.
I think you could play around with the wedge angle to find the happy medium between a nice tight fit and enough stress to crack the acrylic. Since the acrylic isn’t going to compress much, it wouldn’t take much of a wedge at all do do it.
