I created a fun little Christmas lantern that slides over a light in the Christmast tree (make sure your lights don’t get hot!)
It’s cut with 2mm material and is about 6cm tall. If you use a smaller thickness (paper?) the tabs will be too large. If you use a larger thickness, you should probably rescale the entire thing to match.
I filled the “windows” with regular printer paper that I cut to match.
cheers,
mattias
