We have been taking our seven-year-olds on lots of walks around the neighborhood for the last two months. I wanted them to begin to see the neighborhood as an integrated landscape rather than just rows of houses going by, so I made this. It is made up of 13 topographic layers cut from white presentation board (1.2 mm thick) and housed in a closed box. Water features are of blue laid paper my wife had laying around. The neighborhood’s streets are engraved on the acrylic upper panel. Each topo layer represents 20 feet of elevation.
It’s been fun to see them plotting routes for our walks on the map, and to see them beginning to understand the ways that topography impacts their movements and lets them predict where they might find water…
The black lines are on the underside of the acrylic window. That is, I engraved a mirror image of the street layer, spray-painted it black (before removing the masking), and then flipped it over for final assembly. The street names are negative space inside the engraved areas. They present as white due to the white paperboard beneath.
Thanks all, I appreciate the replies! This was a very time-consuming project, particularly the creation of the design files. I started with USGS topo maps and extracted the lines from the PDFs, which has the benefit of matching the official maps—but requires lots of manual work! I don’t recommend that approach…
