I am making some dog steps for my old suck of a dog so she can get on my bed safely.
The cut pattern has been placed on four separate artboards (sized 19x11 each) in the same file. Is there a way to transfer the artboards to glowforge easily, or is it better to save the project as 4 separate files?
There is a way, I remember it being mentioned as a multiple artboard transfer, but you are going to have to wait to hear about it from someone more savvy than me. I generally just create 4 files.
When I have large projects (multi sheet). I either put them into one drawing but with the parts grouped and colored so that I can move the image around in the forge and print each bit separately or I break them into different files. I have not decided which is easier. I am leaning towards one big file.
This is what I do the times I have more than one artboard. Just use the usual copy command on your artboard and then you use the paste command in the Dashboard. So much faster and then I just either rename the file as they will all show up as ‘pasted design’ or delete them if I do not need them again.
