Trying out the new NON vinyl!
It’s been so long since I’ve done a shirt I forgot how tetchy they are.
My Tshirt (recovered)
Have you tested it yet? The glowforge symbol has a lot of little holes, wondering how those would cut. It might need a little bit of cleaning up? I haven’t tested the new vinyl, i hope it turns out well!
Also, after you clean it up, don’t forget to flip the design – it should be “backwards” before you cut it, the iron on process will flip it back the other way :slight_smile:
in the process of editing…
Sorry. didn’t realize how awful it was without fill.
trying to remove this - it’s crap
But the design is really cool! It will look great when you get it all cleaned up. :slightly_smiling_face:
thank you for all the help and comments!
i’d like to be able to say I cut it, but there’s an issue
What is the issue? You haven’t selected the material.
i can’t. it should auto select, at least that’s what the package says. and there is no setting for this material. when I tried to use the Eco Blue setting it just gave me dire warnings about vinyl
this is a new machine. i’m afraid to experiment
And I couldnt find it for sale in the shop, either. The Pastel pack
I think you can choose any of the iron on settings as a start.
Screenshot 2023-08-10 at 5.16.58 PM
The white iron on cut settings are 300/35
okay. i’ll experiment when the warranty is up!
Are you using a Glowforge or the Aura?
a pro
There would be no problem using the preset for White iron on. It is Proofgrade material and you won’t damage the machine. The worst thing that could happen is that the design doesn’t cut perfectly. The dark color iron on presets are in the 500/75 ish range, but the white preset is 300/35.
Thanks a lot. i’ll give it a try
You can get a better source under media assets.
