I posted a link to it above, It’s the “art stamp laser polymer” in the descriptions And product selection and the “laser photopolymer clear” in the product thumbnail (lower right)
I don’t really have any more information than what is available there. It’s a clear, slightly tacky, slightly squishy material that engraves well, holds ink, and can be stuck to acrylic. Don’t cut through the cover sheet or the backing. Large stamps get tricky with inking and applying even pressure.
I used to measure the thickness of the material with calipers. However, now I just use the auto focus feature.
I think 185 power is from before Glowforge changed their power scale to 1000. I think maybe @cynd11 or another long time user may be able help with a conversion.
I now use stamping products from JMP Rubber Stamp Materials, polymer stamps usually. I went down the rabbit hole of stamping and purchased a Misty and it changed my stamping for the better.
I’m inclined to think that when you said 100 speed, 185 power you got the numbers reversed. As far as I know 185 power has never been a possibility. So I’m thinking you used 100 power, 185 speed.
I’ve never that rubber material so I have no more info on that.
