In my description above I forgot to mention that I had to do a Pathfinder—Unite command after doing the Outline Stroke. Otherwise you will not get “innies” and “outies”. I hope that’s clear.
I will edit the info in my posting to include this.
Hear is the final remake of this file. I’ll post it to Thingiverse as a remake in a couple days, wanted to make it a Glowforge exclusive for a bit!
Enjoy! It’s REALLY beautiful. Formatted to fit one sheet of proofgrade.
Hmmm…not sure why this isn’t uploading correctly. What am I doing wrong?
Apparently I can’t upload SVG files, so here’s the .ai Forest_Tea_Light.ai (1001.9 KB)
Everything came through with a black fill instead of stroke; must be your export settings. But it was an easy fix–just select all and change to stroke, no fill.
You did a great job–the panels are fantastic!
Edit: just noticed one little thing, there are about 3 stray points. They will laser, so you’d best remove them (Select…Object…Stray Points, then Delete).
As it is, it defaults to an engrave. You can convert to cut, but better to indicate that in the design file.
Take the fill out of the panels that make up the sides and bottom. Just use a stroke. Then the trees images need to have no fill and a different color stroke(or the same color since you are doing all cuts here.) I just like to separate things like this for another level of control. This will ensure you have the ability to arrange the center cutout to cut first. Actually should have made the forest black and the panel outline blue for a default cut order.
That’s how I have it in Illustrator…and how it looks in SVG on my PC, and in glowforge…weird.
In my file, I have the panels set to black, and the outside panel cuts set to blue, so you easily pick which do which. This is really ticking me off. LOL The file doesn’t post the way I made it.
But I have it exported into SVG, and opened on my machine, and it’s fine. When I uploaded it, it turned to all black squares. I watched it in the preview panel.
I thought maybe I did a Save Copy as, so I redid it, and I did use Save as. The SVG is fine for me, when I upload it into here using the upload command, it turns all black. I posted the original AI in my original post. Hopefully that will be of more use.
I was using the original SVG that posted as a bunch of black rectangles. I just cleaned it up in Inkscape and reposted as I saved if from Inkscape. The screen shots I posted were using that original SVG you posted that appeared black on Discourse. It was all engrave on the Glowforge.
