Hi everyone, I just learned a trick on how to upscale your clear acrylic with cardstock paper and then do projects using your glowforge. This is like the wood modpodge version for acryclics! I hope you enjoy: How do I add cardstock to clear acrylic? - YouTube
My first thought was similar. I bet it would work, but the 3M tape is hella expensive. If there was something cheap you could slop on there, maybe squeegee out the excess, and get a nice optically clear bond, it would be great.
Well, let’s see… I didn’t have any craft paper with patterns so I just cut an ad out of a magazine cover, then affixed it to a scrap of Proofgrade acrylic with 3M 467MP tape. It cut fine and the image is very clear.
I thought a clear wood finish might work. I had some water-based polyurethane, and I found a photo to massacre.
I brushed some poly onto the acrylic, pressed on the photo, and then squeegeed it to try and get out the bubbles. When I flipped it over and peeled back the masking, it looked pretty good!
This photo paper is probably darn near water proof though. I will try this again with regular paper to see if it will dry out.
I’ll check out my other adhesives too… This is a nice effect, there must be a way to get a clear bond on the cheap. Thank you for the inspiration @roberta.capp !
