The “download” option is only available on the “style” editing page. Not on the actual map after the style is applied. (Seems backwards to me, but oh well.)
Once I went into edit the style, it showed up. So I will play with that.
Just curious if you can clarify this please? What setting were shared? I was not under the impression the discussion or mention of non proof grade materials was not allowed in MOAG. If this were the case then all the laser tile projects listed there would be problematic. And there are plenty of mentions of birch and poplar ply. Insight is appreciated.
@arh2 Here is a svg version of the Amsterdam Streets if that helps you get started. I haven’t done the water layer yet because I had no idea how many water crossings there would be. It is going to take me a few days work.
it was not my intent to “call you out”. In my experience, shortly after makers begin discussing materials, it segues into “what settings did you use?”. i thought it was a friendly reminder. My mistake was that I thought I was replying to @GFjim so I added you to the message so as not to repeat myself.
I still tweak my map here and there. It has taken some time to get it right and there are still imperfections, but it works. Looks Like @GFjim (Very Kind Of You!) set you up with a nice file! That is very nice! Amsterdam has a neat layout with the beehive so it does make a good laser cut map!
