Utility panel from Lowe’s seems to be a nice type of wood to do test projects on. Comes out to under $2 per sheet once cut down. It’s pretty light weight and cuts easy on thick maple settings and here is an engraving with thick maple bit map engraving. It seems to be a little to much power but for a first guess / test not bad.
Thanks for the info. Will have to check it out the next time I go to Lowe’s. I know I’ve bought underlayment to use for testing, but haven’t yet. I have bought their poplar and used it with good results.
