For those using an iPad or Mac, a data point to post on what’s available for converting a raster (bitmapped) image to vectors…
Vectornator was mentioned in previous threads. It became a free app (on iOS and macOS) back in 2018. It’s still free from the respective app stores and continues to undergo frequent updates. Their feature is called AutoTrace, but it’s not initially evident nor intuitive. Their online help makes no mention how to invoke it. The raster image must first be selected, only then will the right panel dialog generate an AutoTrace option. The two adjustable parameters are
- Max Number of paths - initially defaulted at 100
- Min path size - default at 0.0%
Bumping the Max paths to 500, the iPad Pro (2020 A12x processor) took ~5 seconds to convert a photo:
From kicking Inkscape’s tires eons ago, this was roughly the similar result. Minor slivers of white indicating areas where vector patches aren’t butting up congruently. Nudging Min path size to anything other than 0% resulted in garbage.
Beyond that, it’s a capable vector drawing program. I drove it for a few days and got irked at some of the convolutions required for certain tasks.
Vector Q is a renamed one-trick app previously known as Imaengine offered primarily for vector tracing. In this rebirth, the UI has been GREATLY improved and is imbued with additional features — bringing it tantalizingly close to qualifying as a bonafide vector-editing app in its own right. It’s marquee feature shouldn’t be overlooked though; it converts vectors at at a dramatic pace. As a flex on its speed, it offers additional real-time vector style options to chose from.
The algorithm it uses to create vectors make smoother shapes that might prove to be far more useful for Glowforge cutting. The adjacent vector shapes also seem to butt together cleanly.
Another demonstration of its speed can be seen by feeding it a VIDEO clip. It rips through the frames faster than what any mobile device should be capable of.
This is a one-click workflow that might otherwise be much longer on another platform.
The mobile app has a $3.99 pricetag (full unlock). This is also available in the macOS app store. At the time of posting this, it looks like they brought back Imaengine ($2.99) reworked with a cleaner/simpler interface aimed at iPhone users.
Who will be first to laser cut an animation on their Glowforge?
